front turn signal
Does anyone know how to rewire the hazord lights/turn signal,on the front of the car to always stay on when you have just the parking lights on and the head lights, unstead of them only come on when the turn signal is on or when ever you set the alarm?
http://www.bol.ucla.edu/%7Ecchiu1/how2.html
and click on Rewire Your Corner Lights and Rewire Your Blinkers.
Like this ->
<img src = "http://www.geocities.com/tchangk2/Max/My99Max1999/maxfront.jpg">[/url]
Originally posted by BenBlanco218
I know how to rewire the blinkers to alternate with the sidemarkers, but is there a way to keep the blinkers on full-time and still signal?
Re: This is what you need
Originally posted by 1MAX2NV
<img src = "http://www.geocities.com/tchangk2/Max/My99Max03202000/1157_bulb_socket.jpg">
Thats a two element socket
What is that? Is that a dual-filament socket? I've rewired them to stay on, but they dont blink anymore. What blinks if you have them on? Your clearance lights? This will really help me. Thanks. [/I]
http://maximanorth.homestead.com/fil..._mods_rwts.htm
Jack
Re: Thats a two element socket
It will fit with a little modification. There's a little tab about 1mm that gets in the way. Just trim it off with cutter or knife. The socket is the same size and can be turn into the housing to lock it in place.
Look at this pic.
<img src = "http://www.geocities.com/tchangk2/Max/My99Max03202000/1157socket_In_Clearbumper.jpg">
Look at this pic.
Its a TWO element socket. Looking at it, I'd say it will not fit my '96 Max. Look here for more:
Jack [/I]
Jack [/I]
Re: Re: Thats a two element socket
Jack
Re: Re: This is what you need
Yes, it's a dual-filament socket that takes 1157 blubs. Really Simple. Three wires. One wire to the parking light (low-wattage filament), one wire to the turn signal (high wattage filament) and one wire to ground. Now, it will look just like the integra.
Yes and Yes
Will the lights still work for the hazord lights when they are wired like this? Will they still flash when you set the factory alarm?
03VQMAX
Oct 2, 2016 09:36 AM
