Bose Factory System....
Old Mar 25, 2002 | 07:06 AM
97MaxSE's Avatar
Damn, doesn't the Bose factory system sound like you have something n your trunk. Anyway, how should the treble and bass be set to get the best sound out of our Bose speakers? Also, what are the speaker sizes that is in my Max? Thanks.
Old Mar 25, 2002 | 07:59 AM
clee130's Avatar
Speaker sizes are 6.75" or another name for them is 6.5S (6.5" oversized)
Old Mar 25, 2002 | 08:14 AM
dwapenyi's Avatar
To really get the best out of your BOSE system, leave the tone controls flat, at 12 O'clock. Then, if you music needs a little bass, or treble, add just a bit from there.
Oh yeah, and don't determine the quality of your system by a radio broadcast, play a good CD and see how that sounds.
DW
Old Mar 25, 2002 | 10:06 AM
WoPhatMax's Avatar
Bose definitely needs a midrange adjuster
i seem to get the best sound by turning the treble up, bass in mid position (or less if necessary) and a slight fade adjustment to the rear. the biggest problem i've had with the Bose is that my right rear speaker cuts in and out and i cannot seem to be able to get it fixed.
Old Mar 25, 2002 | 10:21 AM
sil SE's Avatar
has anyone had a problem with the volume **** on the newer 4th gen units? mine has lost all of its sensitivity and if i switch louder itll go softer sometimes and other times it just wont work.
Old Mar 25, 2002 | 12:16 PM
GTRBlkMax97's Avatar
I had that problem and got it fixed, I will sell you my head unit if you want, just email me
also are the speakers in the front door 6.5s too?
Old Mar 25, 2002 | 08:20 PM
tvn_1010's Avatar
Can you tell me exactly how I can add an amp to my Bose System? I know & I have try the search but there are so many different answer.
Old Mar 26, 2002 | 05:39 AM
dwapenyi's Avatar
Here;
http://web2.airmail.net/scutchen/max...ht.htm#bosesub
Old Mar 26, 2002 | 07:33 AM
95emeraldgxe's Avatar
do u want to add an amp for the speakers or u want to add subs?
Old Mar 26, 2002 | 11:24 AM
RapidMax's Avatar
Re: Bose Factory System....
Generally I keep the bass and treble flat. If it's a CD with a lot of bass and I'm in that mood I'll turn the bass up about half way. Also if I have the windows and sunroof wide open I turn the treble up a little because the wind tends to drown out the treble and leaves too much bass.
Old Mar 26, 2002 | 11:32 AM
ny96max's Avatar
id keep the bass flat and the treble at like 3oclock.
Ant
Old Mar 26, 2002 | 11:35 AM
NyC97Max's Avatar
the bose is my 97 max has more base than that from my moms 95 max's bose...but then again, the driver door speaker on the 95 blew out so i have to fade it to the rear alot...one thing tho, i thought that u cant switch the headunits, cuz each BOSE headunit is specifically computerized to work with that car only, so that thieves cant steal it and make use of it...is this true, or just sum1 tryin to make me not worry?
Old Mar 26, 2002 | 10:41 PM
tvn_1010's Avatar
Originally posted by dwapenyi
Here;
thanks
Old Mar 26, 2002 | 11:38 PM
ericdwong's Avatar
Also read my long writeup in the FAQ thread up above.
Old Mar 27, 2002 | 06:58 AM
dwapenyi's Avatar
You can interchange most Bose HUs from the 95-99. The 99s were the best looking. As for your bass comparison between the 95 and the 97, I would think that they are exactly the same. The blown speaker must be the change you're experiencing. The Bose system produces it's best bass when all four speakers are at the same level, i.e. balance and fade all set to 12 oclock.
Oh, and there's no computerized security at all.
DW
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
