cut the springs to lower?
Old Mar 25, 2002 | 10:44 AM
danw2481's Avatar
i was wondering if anyone has just cut their springs to lower their max - i have a 95 and i was wondering how bad the ride would be and if the stock shocks would hold up? i was thinking of lowering 2.5 - 3 inches buy cutting them -
Old Mar 25, 2002 | 10:48 AM
NmexMAX's Avatar
dot dot dot ...
Re: cut the springs to lower?
Dont do it, buy sprints or h& r's , the ride will be horrible w/cut springs, and its also dangerous and really bad for the alignment(tires ect) and the car, and its ghetto
Old Mar 25, 2002 | 10:53 AM
Kashoggio's Avatar
Old Mar 25, 2002 | 01:52 PM
NightRider's Avatar
Re: Re: cut the springs to lower?
He's right. Cutting your stock springs 1 to 2 coils is okay, but to get 2.5 to 3 inches, you'll have to cut them in half at least. I wouldn't recommend it because you'll run the risk of breaking the springs. To get that low, invest in some coilovers. You'll gt the same ride with those though but at least you'll remain safe.
Old Mar 25, 2002 | 02:07 PM
JAY25's Avatar
Re: Re: Re: cut the springs to lower?
I cut my intrax springs and other members have cut rear sprints, suspension techniques and eibachs I would not do my stock springs. The spring rate is different on your stock spring keep that in mind. maybe one and half coil, Id just pay what $120 and get some sprints and replace the shocks while you are at it.
Old Mar 25, 2002 | 03:03 PM
95emeraldgxe's Avatar
cutting the stock springs will make your ride feel nasty not to mention it will bottom out on just about every bump and turn u make
Old Mar 25, 2002 | 03:05 PM
1FSTMAX's Avatar
What happens if you heat the coils? Has anyone heated their coils?
Old Mar 25, 2002 | 03:09 PM
NightRider's Avatar
Not totally true. It will only bottom out if you don't have enough suspension travel. Shorter springs won't be the cause. If you invest in bumpstops or shortened struts, you can eliminate that problem. It will, however, make the ride bad.
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
