TORQUE WRENCH size for LUGS on wheels
Old Mar 25, 2002 | 09:47 PM
itsgt's Avatar
this might be a silly question......but searching from the forums no one has really answered this question specifically...or not that i have found on this .org.....
the question is ..... if i would get a manual torque wrench or impact wrench... what size would i need to get (ex. 1/2in, 3/8in, 1in, etc)
THANKS GUYS!!
Old Mar 25, 2002 | 09:51 PM
2dino's Avatar
I beleive 1/2 inch is the popular drive size for 21mm socket.
C.F.
Old Mar 25, 2002 | 10:01 PM
Nismo's Avatar
a 3/8 torque wrench works just fine
Old Mar 25, 2002 | 10:16 PM
itsgt's Avatar
so which is it 1/2in or 3/8in
Old Mar 26, 2002 | 12:07 AM
max808's Avatar
1/2 inch
i use the 1/2 inch, but you probably already have sockets for the more popular 3/8 inch. the lug size is 21 mm.
Old Mar 26, 2002 | 12:16 AM
KWheelzSB's Avatar
Either will work fine with the appropriate sized socket.
Buy whichever one you think you'll get the most use out of, or the one that you already have the most sockets for.
Torque spec. is 85 ft/lbs for the lug nuts. Choose a wrench that has the right range for the majority of jobs you anticipate doing. Sears sells manual wrenches that go up to 80 ft/lbs and another to 150 ft/lbs.
-Just depends on what you want to use it for.
Old Mar 26, 2002 | 05:02 AM
BEJAY1's Avatar
Conecarver
I'd suggest the 1/2" because I use mine as the breaker bar too. Lugs can be though.
Just get a $3 3/8" adapter and it'll work with all your other sockets.
Old Mar 26, 2002 | 07:39 AM
got rice?'s Avatar
like someone mentioned, get the 1/2" drive along with the 3/8" adapter. I believe the 3/8" sockets only go up to 19mm.
Old Mar 26, 2002 | 10:09 AM
KWheelzSB's Avatar
Just FYI, you can throw your torque wrench out of calibration very quickly using it this way. . . not recommended.
Also, it's a good idea to dial thw wrench down to the lowest setting when you're done using it, as this will release tension off the internal spring & further preserve the accuracy of the wrench's factory calibration.
RinconI30
Nov 10, 2015 10:55 PM
minsbang
Sep 11, 2015 08:48 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
