headlights
Old Mar 25, 2002 | 09:53 PM
dynamicmax's Avatar
headlights
I got the hyper white head lights...my fren told me my light burnt out..i flicked the high beam and the bulb worked but when i turned off the highbeam, the bulb wouldnt work..wat does that mean???
the bulb aint burnt out..should i buy a new one?
Old Mar 25, 2002 | 10:04 PM
Aaron's Avatar
Langley AFB Sux
Yes
The bulbs for the headlights are dual filament. One for low beam one for high beam. Your low beam filament blew...thus the reason no light until you turn on your highbeams.
Old Mar 25, 2002 | 10:05 PM
Dhruv's Avatar
the low beam filiment has burnt out, the high beams would work but the low beams wouldnt. there are 2 wires which are high's and lows. the lows are gone so yes u need new bulbs OR maybe its ur wireing harness. i would get my old stock bulbs and check that the low and high beams work. if they do then its ur bulbs. hope this helps.
Old Mar 26, 2002 | 06:50 AM
MAXEJA's Avatar
get an aftermarket wiring harness for the front headlights so that you do not burn ur oem harness up. They will fry the plastic and wires if you are using more wattage.
Old Mar 26, 2002 | 06:53 AM
95emeraldgxe's Avatar
Xenon bulbs have a rather short life span, so if your into xenon lighting - you should carry a few spares in your trunk just in case
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
