springs or shocks?
Old Mar 27, 2002 | 01:22 AM
rguida's Avatar
springs or shocks?
hello, I wanted to know, what makes the difference with the stock suspension,t he shocks or the springs.....like i know se is sporty and gle is luzory but what mader that difference?? thanks a lot guys
Old Mar 27, 2002 | 04:45 AM
Ramius83
The springs are the pieces of the suspension that lower your Maxima. The struts (shocks) are the pieces that dampen the force of the lowering springs. IF you get lowering springs, you will NEED new struts. I have the B&G and KYB AGX combo and I love the ride.
Old Mar 27, 2002 | 06:47 AM
njmaxseltd's Avatar
If you want to keep the stock ride height but upgrade your suspension for better handling your looking at new shocks and struts.
If you want to lower your car for appearance reasons, springs are needed and should be accompanied by new shocks and struts. Lowering your car will also give you even greater handling.
Old Mar 27, 2002 | 08:53 AM
rguida's Avatar
uhm guys either your not listening or im not explaining it well...
I want STOCK stuff, and i know there is a difference between the gle suspension and the se suspension, my question is, is it the springs that makes the difference, of the shocks that make the difference between the two.
Old Mar 27, 2002 | 09:04 AM
BlancMax's Avatar
It's defintely the struts/shocks. I believe the SE has electronically controlled suspension, someone correct me if I'm wrong. The rear springs are identical for SE and GLE I believe, but I'm not sure about the front springs.
Old Mar 27, 2002 | 09:17 AM
BlkCat
Definitely not for a '98 SE, however I don't know about the newer models.
As for the springs they're stiffer on the SE. I test drove a GXE as well as an SE and you can feel the difference.
Old Mar 27, 2002 | 10:52 AM
JAY25's Avatar
GXE soft mushy suspension good ride
SE A bit stiffer suspension, still good ride!!!
just like he just said above me,
njmaxseltd's Avatar
Suspensions differences in SE and GLE
Springs
Shocks/struts
Bushings
Wheel/Tire sizes
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
