Front Left Heated 02 sensor
Old Mar 29, 2002 | 09:56 AM
jlee4's Avatar
I just did a self diagnosis, and the car said that my front left heated 02 sensor is bad, can anyone tell me where i can find that sensor and how to replace it?
Old Mar 29, 2002 | 11:04 AM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Re: Front Left Heated 02 sensor
Reset your ECU, the CEL light should go away. If it doesn't come back on again, then no problem. If it comes back on (same ECU readout) then you'll need to buy a replacement sensor (ie, Courtesy Nissan etc.) It's not cheap.
Ange
Old Mar 29, 2002 | 06:47 PM
MIXXMAX's Avatar
Re: Left Heated Front O2 Sensor
I replaced mine mine last summer. It's located on the passenger side close to the manifold. It's hard to explain exactly, but if you have access to a Hayne's manual I believe it shows a photo of the harness, and then you can follow the wires to the sensor. This part is fairly expensive compared to the rear O2 sensor which I replaced at the same time.
Old Mar 29, 2002 | 08:58 PM
tm96max's Avatar
go here: http://www.courtesyparts.com/A32_O2-sensors.html
It shows a picture of the exhaust and where the O2 sensors are located.
rbuswell
Nov 12, 2016 04:11 PM
homeyclaus
Sep 3, 2015 06:15 PM
lowpost99
22
Sep 2, 2015 04:38 PM
Flores94
Aug 11, 2015 12:53 PM
rhonster
Aug 6, 2015 05:46 PM
