Headlight is melting!
Old Mar 29, 2002 | 01:20 PM
bolido2000's Avatar
I installed Showoff Krypton headlights (80w) and the right side just went out!. I checked and the thing that connects to the bulb (name?) is melting. Can I just buy a new connector (the thing that connects to the bulb) or I have to get the APC harness?
BTW, this is happening 8 months after I installed them
Old Mar 29, 2002 | 01:25 PM
SuDZ's Avatar
Re: Headlight is melting!
Yep thats the warning with when you go overwattage on your bulbs. You might be able to get a new connector at a dealership or maybe a junkyard but risk either the same problem again or having it burning out wires somewhere else and giving you more problems. Might as well upgrade the harness and be done with it.
SuDZ
Old Mar 29, 2002 | 01:44 PM
BlkStnValyMaxima's Avatar
You can pick up 9004 harnesses at any Pep Boys or auto parts store, just look in there electrical section. You can connect them right in to the wires for your old melted harness. BUT!! They will also melt! I would say get the APC harness if you really want to run those bulbs.
Old Mar 29, 2002 | 01:45 PM
NickStam's Avatar
the car us supposed to use 65W bulbs, and your using 85W. Why do you think it's happening?
Old Mar 29, 2002 | 02:10 PM
bolido2000's Avatar
Can someone tell me a good place to get the APC harness? thanks
Old Mar 29, 2002 | 06:28 PM
MIXXMAX's Avatar
The stock 9004 harnesses in Maximas can only handle a safe wattage of 65W or less. Any higher wattage will MELT the harness, or sometimes the bulb may even explode from overheating. That's when you'll definitely run into problems, because the shattered glass will be sitting inside your headlight. You MUST upgrade to a higher wattage harness!
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
