Auto trans fluid change 99Max
Originally posted by dakota
I am going to drain and change the fluid in my 99 Max auto trans and need to know how much fluid I will need. I intend to replace it with Mobil 1 synthetic. Thank for your help.
Note: The first time I changed it around 100,000 the local Nissan dealer incorrectly told me to just unscrew the plug. They did not recommend pulling the pan and changing filter. Around 150,000 the transmission started to slip and I underwent a very costly transmission rebuild - which may have been caused by my failure to change filter.
Dakota...my '97 took exactly 6 quarts the last time I changed it (drain and refill only). The stated capacity in the manual is much greater due to the fluid that resides in the torque converter. You won't be able to drain the torque converter unless you drop the pan. Dealers have a machine that will pump out and replace ALL the fluid in the transmission. I had it done at a Nissan dealer for ~$125.
Originally posted by goldmax
... ... Dealers have a machine that will pump out and replace ALL the fluid in the transmission. I had it done at a Nissan dealer for ~$125.
Buy 6 quarts to be safe.. When I did mine I only bought 4 quarts.. And I ended up having to drive to Autozone with low tranny fluid to buy more. Make sure when you check your fluid level you do it using the owner's manual's guidelines. It actually took me two days worth of driving to get the fluid level right. But it took about 5-6 quarts.
ZuM
ZuM
Jiffy lube machine
I was wondering as to what they do exactly with this "magic sucker pump" because Valvoline does the same thing--which is a drain, pump out--and I asked three valvolines on the phone b/c I wasn't sure if one guy knew what the heck he was talking about. But they only charge about $25 for this service. Am I getting this wrong? But they specifically said they hook your car up to the pump machine and pump out all old fluids and then do a complete refill.
I know what I got done at the Dealer a few months back was just a drain and refill which was about 5 quarts worth. But does pumping out everything require for the shop to open the transmission pan?
And btw, what is this mention of a transmission filter--I thought there wasn't one--that was what the dealer told me...
can anyone shed some light on this?
Brian
Brian
Re: Jiffy lube machine
Brian
Brian
... ...But does pumping out everything require for the shop to open the transmission pan?
Re: Re: Jiffy lube machine
thanks you guys
So at jiffy lube it costs about $80--that seems to be a pretty decent price, considering that the Nissan dealer in my area charged $65 for just the drain and refill. I think after the winter and at the end of my 10k of refil, I am going to go to either valvoline or Jiffy lube and have them hook it up to a T-tech and take care of it.
Synki--
I am assuming then that you can bring your transmission fluid for them to refill with, correct?
How is their service? pretty decent?
well, I am only at 30756 as of today, but because I live in NYC and all my trips are very short--1-3 miles, I know that the service requirements are a bit different--such that I can probably put on 7K in a year but I still need to do two oil changes.
Synki--
Re: thanks you guys
Synki--
Synki--
You can bring in your own fluid, it will save you about 3-5 bucks ro so, cant quite remember, i quit there about 2 months ago. Their service it pretty good. They will bring your car around back and do it outside (Thats wut we did here in NJ) and they will tap into 1 of your tran cooler lines. THe service takes about 20 mins or so. Let them know of you have like a aftermarket trans cooler too, that would call for an addition quart of fluid.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
