VERY weird problem with my car
Old Mar 29, 2002 | 09:15 PM
rguida's Avatar
OK, i;m at the poughkeepsie mini meet over here, and i go into the local duncan donuts.....when i come out, I looka t my maxz. All of a sudden the parking lights go on by themselves......I look at the back and the dash and all those lights are on as well, but not the headlights.... note: this is all occuring with the light switch on the "off" position. So, finally i take out a fuse "int ill", and the outside lights go off, but the dash lights stay on.....i could not remedy the problem. WHen i start driving home I notice the check engine light go on...so im thinking WOO HOO theres my problem. But when I check what the problem is "53" I get "Front Right Heated O2 sensor"... are these two related???? Can anyone think of why my lights would stay on, like in parking position without headlights on? thanks in advance
-chicken
Old Mar 29, 2002 | 09:34 PM
NYBlakMaxx's Avatar
Damn man your check engine light went on after??? That sux. You didn't get the problem fixed in the parking lot after I left....darn ECUs
Old Mar 30, 2002 | 04:55 PM
rguida's Avatar
FOr those who read about this problem HERE was the answer....
i had my sunpro tachometer grounded to my instrument cluster...the wire was loose and touching other parts of the back of the cluster...after removing this wire, all of a sudden my lights started to work and my front right oxygen sensor CEL code was not popping up at all...and i did not reset the ecu either.....hmmm....
Old Mar 30, 2002 | 07:32 PM
StygianMax's Avatar
I had an almost identical sounding problem w/ my old '87 Legend Coupe. The problem turned out to be a fault in the light-control arm (I think it might be called combination-switch arm?). It's the arm that extends to the left from the steering column. It's also connected to the turn-signal switch.
It thought it was a faulty contact inside the arm & tried to get at it but the arm is all fused together & there's really no way of disassembling it. Since it was winter at the time & getting really dark at 5 pm (I'm in Toronto), I had get an OEM one super quick to replace it for obvious safety reasons. The whole combination-switch arm had to be replaced ($$$).
Old Mar 30, 2002 | 08:43 PM
Conrad283's Avatar
I need a truck
glad everything worked out good for ya
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Jcof88
Aug 3, 2015 10:43 PM
yat70458
Aug 3, 2015 01:16 PM
