whats power shifting?
Old Nov 22, 2000 | 09:21 PM
max95q's Avatar
is it bad for the trans mission?
Old Nov 22, 2000 | 09:38 PM
Jimp
I am not really sure but I have heard that it is bad. I would not try it!
Old Nov 23, 2000 | 12:06 AM
Maxima97GLE's Avatar
Power shifting
I heard it is bad, too, but I do it sometimes. But it seems that whenever I powershift and then throw it back into regular drive... the gears change nicer and at a lower rpm... but then again... my Maxine could be weird.
Old Nov 23, 2000 | 12:14 AM
PiotrC70's Avatar
Re: Power shifting
Like one of the other guys said on the General Discussion board... Power shifting is basically planting your foot on the gas, shifting, while never letting your foot off the gas one bit... It can be bad if you don't have an upgraded clutch... if you slip and grind the gears, there's another...
Old Nov 23, 2000 | 08:23 AM
Daniel B. Martin's Avatar
Re: Re: Power shifting
Powershifting is an abusive driving practice. It will burn out a clutch quickly. It can be condoned only in the setting of a true drag race run on a drag strip, where a race may be won or lost by a tenth of a second.
Old Nov 23, 2000 | 09:58 AM
ZuMBLe's Avatar
Re: Power shifting
They are talking about 5-speed powershifting.. =P I sure hope you keep your foot planted when you shift through your auto.. =P And that different feeling you get after a good hard run is probably your tranny fluid being all heated up. Thats why the tranny shifts a little different. Hehehe.
ZuM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
