Need advice
Need advice
Hey, Im new to the whole forum here, Ive got a black 97 GXE, so far all i have on it is the chrome window tints which are looking good. I need some advice on what/how to do to it and in what order is smart...
appearance-wise I want the red/clear tails, the clear corner lights, and fog lights/new headlight bulbs, aluminum dash kit, and the diamond-cut floor mats - if anyone has any for sale, email me at keyzursoze@hotmail.com or IM at keyzursoze
im also looking to drop the car down 2 inches or so and get a set of 17's.. i found a set at http://www.whalentire.com/wheeldetai...0H43GM&size=17 that i think would look good since the car is all black with chrome trims.
whatever advice u have on modifying my car would be helpful
thanks
thanks
You can make the red/clear tails. You can buy the clear corners off of either ebay or www.custommaxima.com . Custommaxima also has the aluminum floor mats I think and probably the dash kits. About the springs, I think Sprints drop 2 inches, but I'm not positive. If you look in the upper right hand corner, there is a link called search. Use that to help answer some of your questions.
Check out www.CustomMaxima.com and the Maxima.Org: Parts For Sale Forum. You should find everything you need between the two. Also try searching (top-right corner), you will almost everything there is to know about Maximas there.
-Cyrus
-Cyrus
Alright, performance. The best power combination would be a y-pipe and an intake. Your choices for y pipes are Stillen, Budget, Warpspeed(www.warpspeedperformance.com), and Cattman. Intakes, basically, you can go with either a cold air intake or a popcharger, which is a cone intake. You can always do catback exhaust, but that is only 1 or 2 hp, mostly for sound and looks. Again, search has all the answers.
