Flushing Trans Fluid
Old Apr 3, 2002 | 02:36 AM
magic_max's Avatar
I plan on flushing my trans fluid by running the car and adding at the same time until I see the fluid coming out become clean. How fast does the fluid come out of the return line? Thanks in advance.
'96SE
Old Apr 3, 2002 | 04:12 AM
Jime's Avatar
I used a 1 gallon clear windshield washer jug, put the end of the transmission hose in the jug and get someone to start the car and then yell when you want them to stop, it comes out fairly quickly but not enough to force the fluid out the jug top, but make sure you hold on to the hose and the bottle to keep it steady. It takes about 15 or 20 seconds to get half a jug which is what I did and then refilled and did another half a jug till it came clear. It took 10 litres for me. I have read that some people did it in 1 gallon increments and others 1/2 so I did the half.
I did a cooler install at the same time so I had a long enough hose on the output from the transmission to easily run to the jug but the stock hose is short so might be advisable to put a longer one on or attach an extension to it.
Also just put back in the same amount you take out and then run it a while after you are all finished. I found that the stick showed low at first but came back after a short drive so I was glad I didn't add the extra litre I had purchased.
Old Apr 3, 2002 | 10:04 AM
magic_max's Avatar
Thanks so much for the tip.
'96SE
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
