Hooking up air/fuel rat guage....
Old Apr 3, 2002 | 09:09 PM
Dahnryman's Avatar
if im not mistaken there are 2 wires on the front o2 sensor....but which one do i splice into....black or white?
can anyone help me with this befor i cut the wrong wire?
Old Apr 3, 2002 | 10:51 PM
Chunger's Avatar
My other car is a Hybrid
Re: Hooking up air/fuel rat guage....
This has been asked before... but here's a pic lazy! (some other member posted it)
Click me if I'm LAZY
Old Apr 4, 2002 | 04:23 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: Re: Hooking up air/fuel rat guage....
ok.. there are two circled..
which one? that still did not answer his question!!
Old Apr 4, 2002 | 04:49 AM
maximus75's Avatar
50 is the right sens. 51 is the left. Doen't matter which one you use.
Old Apr 4, 2002 | 05:29 AM
rguida's Avatar
uh...I didnt cut into either of those...i used something like #57....which should be the rear o2 senson thats on the catalytic converter???? (95-96)
Old Apr 4, 2002 | 05:32 AM
maximus75's Avatar
56 is the rear sens however its not as acurate because by the time the exhaust has reached it, it has been altered by the cats. Its fine to use if you have no cats.
Old Apr 4, 2002 | 06:26 PM
Dahnryman's Avatar
not to sound dumb....though i have never done this befor what is that a picture of?....is it the side of and ecu....if so arn't 97 different form 95-96?
Old Apr 4, 2002 | 06:52 PM
mtrai760's Avatar
'Trynna' is not a word
You could just use the stripped shielded wire off the wires for the O2 sensore by the front bank and make this much easier on yourself.
Old Apr 4, 2002 | 06:58 PM
it is not a good idea to tap in "shielded" wires.. there is a reason they are shielded..
Old Apr 4, 2002 | 07:03 PM
j-95G's Avatar
actually, if you are tapping into the o2 sensor under the hood, there are 3 wires. on the plugs to the sensors under the hood, (there are 2- a front and a back) there's a red, a white, and a blue. the rear sensor has the same scheme, just a stripe on each wire.
you need to tap the blue one. i tapped both sensor plugs and got the same results from each one.
i actually got a seperate o2 sensor to install specifically for running my a/f gauge. it's an NTK part #21000. it has a single wire and should be more accurate than piggybacking the ecu. this might be something to consider. it's not expensive at all. the sensor only costs about $25 and you can get a bung to weld into your exhaust for about $6 from summit.
good luck!!
Old Apr 4, 2002 | 11:48 PM
Chunger's Avatar
Re: Re: Re: Hooking up air/fuel rat guage....
I'm not sure about the years... but I don't think they are different (based on Cheston's use of 95 ECU on his 97)
The picture is of the harness side (hence the HS on the pic)... in otherwords, the way you would see it on the ECU. It's easier to do than running the wire from the engine compartment IMO. Just remove the plastic cover on the passenger side foot area. Take care with the harness/ECU though and keep in mind that you have to fit everything back under the clear plastic piece of the harness.
maxima297
Sep 24, 2015 01:18 PM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 12, 2015 01:54 AM
Mcnabb34
Aug 11, 2015 08:45 PM
MikesChevelle
Aug 9, 2015 11:50 AM
