Cornerlight next to the headlight
Old Apr 4, 2002 | 05:21 AM
aggroman13's Avatar
Hey, my cornerlight next to my headlight is reallly dim, i have nice bulbs in pretty much everywhere except for those and its throwing all the other lights off becuas they look really good...how do i make this brighter...just new bulbs?
Old Apr 4, 2002 | 05:27 AM
rguida's Avatar
Re: Cornerlight next to the headlight
search is your friend
but you can tackle this by either cutting off one of the nubs and putting the bulb in, in reverse. this should cause the 22 watt side to be lit all the time. there is also a way to rewire but from what I hear butting the nub is the easy way to go.
Old Apr 4, 2002 | 06:40 AM
SuDZ's Avatar
Re: Re: Cornerlight next to the headlight
Make sure it is the top nub you cut off.
SuDZ
Old Apr 4, 2002 | 01:10 PM
MENYCE's Avatar
Ithought that this was only possible with the 97-99's?
Old Apr 4, 2002 | 01:37 PM
SuDZ's Avatar
Might be actually. I was just assuming it was the same as mine. His is a 1996. It may be entirely possible that this mod doesnt work for him the same.
SuDZ
Old Apr 4, 2002 | 01:51 PM
xsp00kyx's Avatar
SuDZ
yo aggroman go to www.custommaxima.com and search for the polarg hyper whites kid
Old Apr 4, 2002 | 02:12 PM
mzmtg's Avatar
Minister of Silly Walks
I cut the upper nub off and it works great.
I have a 95.
Old Apr 4, 2002 | 02:45 PM
MENYCE's Avatar
I have a 95.
So what does it do? Does it just stay bright all of the time? I know that the 97-99 are just always dim and ours illuminate when the blinker is on. I don't have my max right now, but if this works, I'll be choppin that nub off ASAP.
Old Apr 4, 2002 | 03:21 PM
jdm_mboy's Avatar
it lets you use the other filiment on the dual wattage bulb...
try it you'll love it! 10x brighter....
just snip and reverse and voila!
Old Apr 4, 2002 | 04:37 PM
aggroman13's Avatar
thanks for all your help guys....haha, what is the nub?
Old Apr 4, 2002 | 05:06 PM
mzmtg's Avatar
When you take the bulb out, you'll see that there are two offset nubs on the base of the bulb. These are to ensure that it only fits in the socket one way. You have to cut off the upper one (I used nail clippers) so you can put it in the socket backwards.
This makes it use the bright (27w) filament all the time.
If the bulb seems loose in the socket, smush the metal part of the socket a little with some pliers to hold it tight.
Old Apr 4, 2002 | 06:22 PM
MAXEJA's Avatar
i did that mod early on and i have gone through so many bulbs, its well worth it to get that nasty dim orangy light out of there, but what can sustain the new power for continual use. What bulb brands do you go with?
Old Apr 4, 2002 | 06:27 PM
hakk97se's Avatar
Good info:
All the info you ever wanted to know about modding your clearance lights is right here:
http://forums.maxima.org/showthread....hreadid=110399
Old Apr 4, 2002 | 06:47 PM
Vyrus's Avatar
Do the rewire and get some PolarGs like someone said above and you will be satisfied. Just got my bulbs today and they are really white. Best I've seen so far.
-Cyrus
Old Apr 5, 2002 | 12:35 PM
MENYCE's Avatar
What kind of bulbs have you gone through? I want to do this mod badly, but I have PIAA Xtreme Whites. At $11 a pair, I don't really want to have to keep replacing them.
Old Apr 6, 2002 | 12:25 AM
xsp00kyx's Avatar
-Cyrus
what does rewiring do when you already have polarg bulbs??
Old Apr 6, 2002 | 07:12 AM
rguida's Avatar
rewiring or cutting off the nub do the same thing...one is just simpler then the other...
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
