New Dyno results!
Old Apr 4, 2002 | 05:18 PM
turbo97SE's Avatar
New Dyno results!
Hey guys
Thought I'd let you know I dynoed today!
The results were:
Drum roll please! .....
352.2 HP and 349 ft-lbs of torque!
How's that for a 4th gen maxima! The clutch kept slipping so it was difficult to get a good dyno chart. I'll scan the chart a bit later
Nigel
Old Apr 4, 2002 | 05:24 PM
Jeff92se's Avatar
I'm needing a caw
Son of a Biatch!!! 4th gear right? Still at 4 psi??? Nice job man.
Old Apr 4, 2002 | 05:25 PM
Cumalot's Avatar
Take it to the track!
Old Apr 4, 2002 | 05:26 PM
Ramius83
That is at 4 psi, holy cow man. Once I get that manual tranny in, be expecting an order. What else have you done to get those numbers, ie. boost controller, etc. Thanks guy.
Old Apr 4, 2002 | 05:27 PM
JsL's Avatar
JsL
Old Apr 4, 2002 | 05:28 PM
MAX2000JP's Avatar
Re: New Dyno results!
Originally posted by turbo97SE
Hey guys
The results were:
Nigel
WoW....Thats amazing. What boost are you currently running??
Old Apr 4, 2002 | 05:30 PM
ILoveMyMax's Avatar
Re: Re: New Dyno results!
INSANE.... watch out Acura...
Old Apr 4, 2002 | 05:36 PM
Cumalot's Avatar
Re: Re: Re: New Dyno results!
lol...Acura? Watch out everyone!
ILoveMyMax's Avatar
Hey this flame isnt coming from me but one of my good friends who has a turbo eclsipe said that there is no way possible u can produce numbers like that at 4 psi? can u explain??? also is that 352 fwhp or crank? thanks peace
Old Apr 4, 2002 | 05:41 PM
Ramius83
dyno = fwhp.
Old Apr 4, 2002 | 05:45 PM
The_Bomb's Avatar
Adam
Old Apr 4, 2002 | 06:04 PM
MAX95RUS's Avatar
MAXIMA
Old Apr 4, 2002 | 06:08 PM
Mad Dhan's Avatar
whoa, can the tranny hold that power? thats alot of FWHP for 4psi, bust out the scan.
Old Apr 4, 2002 | 06:30 PM
turbo97SE's Avatar
hehe! Sorry it's not at 4 psi! Hehe forgot to mention. I have a boost controller and set it to 9.3 psi. When I put it on the exhaust alone, it was 5.5 psi. There wasn't much gain in power, but then again we only did one run and the graph looked funky. The torque was at 294 ft-lbs at 5.5 psi, the power was about 270 HP, it looked really funky though!
I set it to 8.64 psi and it gave about 334 HP. The clutch can't hold it. You'll see a dip in the graphs cos the clutch slipped at 9.3 psi. . Why the odd psi numbers...well it's all in metric so I had to convert.
Now I need to get a new clutch in order to do a proper dyno. . It kicks butt on a drive!
I will scan the chart at about 10 pm MST ... oh all numbers are measured at the wheels.
Nigel
Old Apr 4, 2002 | 06:35 PM
MardiGrasMax's Avatar
WOW
Old Apr 4, 2002 | 06:47 PM
turbo97SE's Avatar
Originally posted by MardiGrasMax
WOW
Hey Mardigras!
question for ya ... if I want to run 10 psi, do I need anything else? Like AFC or something? I haven't checked my plugs yet ... I need to do that. Unfortunately, their O2 sensor was not working today, they just got it 2 weeks ago.
That's about as high as I want to go. I will probably keep it at 5.5 psi and hit 9.3 or 10 psi when I need it.
By the way, does anyone have a recommendation on clutch? ACT modified street disc won't hold cos I am pretty close to 400 HP at the crank. The only one he (my tuner)could find was clutchmasters. I don't want pucks!
Nigel
mtrai760's Avatar
'Trynna' is not a word
I want a turbo!!!!!
Old Apr 4, 2002 | 07:34 PM
Sin's Avatar
Sin
Hey guys
The results were:
Nigel
What kind of internal engine work have you done?
Old Apr 4, 2002 | 07:44 PM
carnal_c30's Avatar
Former Sponsor
try Jim Wolf Tech clutch, I dont know if it would be good enough for what ur running hehe but it gives good feel
Old Apr 4, 2002 | 07:57 PM
97GreenMax's Avatar
WOW! That is awesome.
Old Apr 4, 2002 | 08:04 PM
JPMontoya's Avatar
Originally posted by mtrai760
I want a turbo!!!!!
Old Apr 4, 2002 | 09:45 PM
-Boost_Krazy-'s Avatar
that's awesome man. It takes about 18-19 psi to get those kind of numbers on dsms.
Old Apr 4, 2002 | 09:56 PM
mitch33x's Avatar
Nigel, very impressive...time to hit the track
Old Apr 4, 2002 | 10:59 PM
RS Motorsports's Avatar
Holy **** dude. Nigel i hafta get a ride with that thing turned up to 9 psi. Hope you can make it to bandimere on the 13th.
Ryan
Old Apr 4, 2002 | 11:01 PM
turbo97SE's Avatar
OK Here is the dyno chart:
Dynorun 12 is actually @ 9 psi not 4 psi. As you can see, the dips are where the clutch gave out on me! It may have made a little more power and torque, but it's hard to tell at this point.
My engine is all stock at the moment. I think I'll hold of on building the motor for now. I am happy with 350 HP . My tuner was even happier than I was. He's an awesome guy. He would have been happy with just over 300 HP!
I checked the plugs to see if I was running lean. They seem to be OK. I think they are running HOT. That is to be expected since I am running stock heat range ... I'll have to do a search, but where's the best place to get 2 heat ranges colder? I'll probably get copper plugs for cleaner ignition spark. How are iridiums?
I will probably go to 10 psi and that will be it. I probably won't bother to Dyno it though until later. That should put me in the 360s+ for HP and torque.
BOOST IS FUN!
I can't wait to see how Alex's turns out. His should show even better results for the same PSI since he has a 60-1 ... more efficient.
Old Apr 4, 2002 | 11:34 PM
1/3There2/3ToGo's Avatar
BOOST IS FUN!
Love your sig dude...cracks me up. Congrats, hope you can make it to bandi.
Kirk
Old Apr 4, 2002 | 11:42 PM
BriGuyMax's Avatar
Hey Mardigras!
Nigel
I think an ACT street disc should hold your power just fine. SX7R ran 385 tq to his ACT...and it didn't slip at all....I run my 100-shot on my ACT...and have no problems at all....NOS guys know how hard Nitrous hits....and it holds on like a hooker in debt.
Old Apr 4, 2002 | 11:54 PM
97ABMAX's Avatar
Damn, nice job!!!!!!!!!!!!!! Ill have to get a ride when you give dafro one. Take Care
Old Apr 5, 2002 | 12:25 AM
OriginalMadMax's Avatar
Whoa! You're moving out of ACT street clutch range! Maybe try a JWT Stage 2 clutch ...
Old Apr 5, 2002 | 04:49 AM
nismo2020's Avatar
Needs non-Maxima Friends
ACT
nigel get an ACT clutch and you will ripping your passengers heads off (with a proper break in period). i can only imagine what 352 horses feels like with an ACT clutch. anyway good job once again. i smell a canidate for May MOTM.
Old Apr 5, 2002 | 05:23 AM
SteveChicagoSC's Avatar
Great Numbers!!!
Old Apr 5, 2002 | 05:47 AM
Lime's Avatar
I repeat...you are my hero
Will you marry me!?
Old Apr 5, 2002 | 06:30 AM
turbo97SE's Avatar
Originally posted by SteveChicagoSC
Great Numbers!!!
I noticed in your sig you have 345 and 375 for numbers AND you're auto ! Those are GREAT numbers! How much boost are you running?
Old Apr 5, 2002 | 06:45 AM
Sprint's Avatar
I know a maxima at 450 hp with an ACT clutch holding up just fine
Hey Mardigras!
Nigel
Old Apr 5, 2002 | 06:48 AM
HondaKiller718's Avatar
Very nice job
You are an asset to our community, keep up the good work!
Old Apr 5, 2002 | 07:08 AM
JPMontoya's Avatar
Do you guys have to worry about reinforcing your front end due to the extra hp?? Does it even matter??
I want a bi-turbo setup!!
Old Apr 5, 2002 | 08:54 AM
biturbo
To work this, you'd use smaller turbos. They might spool a bit faster, but you'd probably lose some top end.
Old Apr 5, 2002 | 08:56 AM
clutch
Really? The street setup, not pucks? They are only rated to about 35o lbs. of torque, and he's past that already. It might last, but how long? Depends on launches, I suppose. Shred the tires, shred the clutch .... That's why I suggested the JWT Stage 2, rated for more power.
Funny, they don't list clutches for Maxima on their website (Cattman sells them, $425) but they do list TURBOS for Maxima. Anything going on with your setup???
Old Apr 5, 2002 | 10:01 AM
Jeff92se's Avatar
I'm needing a caw
Re: clutch
I'm not sure but I "think" JWT uses another clutch maker as their own kit. Maybe it's a combination of parts but I don't believe JWT is a maker of clutches/pressure plates etc... Kinda like a Stillen deal.
Old Apr 5, 2002 | 11:27 AM
Re: Re: clutch
It wouldn't surprise me. Their basic clutch specs very close to ACT. I wonder ... anyway, mine's worked well for me.
