Air Horn
Old Apr 4, 2002 | 06:56 PM
Rufus's Avatar
Air Horn
where can I get an air horn? I want one that is loud enough to knock someone off a bike! not really but I want to give someone a wake up call when necessary. any websites would be helpful.
thanx
Old Apr 4, 2002 | 07:01 PM
turbo97SE's Avatar
Re: Air Horn
thanx
Ebay's a good place to start!
Old Apr 4, 2002 | 07:07 PM
Rufus's Avatar
Re: Re: Air Horn
how do i know if it will fit on my maxima? and how simple are they to install?
Old Apr 4, 2002 | 07:36 PM
turbo97SE's Avatar
Re: Re: Re: Air Horn
It's a piece of cake if you want to use your stock button on your steering wheel. It's more of a pain if you use separate switch. I have Dixie horns in mine ....kind a cheesy but it's funny and distinct! I have 5 horns in mine! . It was a pain in the butt for me cos I had to find a place for them all. our engine bay is not the roomiest. I made brackets for the horns and put them between the radiator and front grille.
Old Apr 5, 2002 | 07:24 PM
teraspeed's Avatar
Re: Re: Re: Re: Air Horn
Cool, I did the same thing! I have the Hella dual airhorn kit, though. I saw a writeup that suggested installing them behind the fogs. Seemed to make things a lot more complicated. I just welded up a couple of stainless brackets and used the existing pre-threaded holes on the front brace by the radiator.
Old Apr 5, 2002 | 08:20 PM
1MAX2NV's Avatar
http://photos.imageevent.com/1max2nv...Air_horns1.jpg
http://photos.imageevent.com/1max2nv...Air_horns4.jpg
Old Apr 5, 2002 | 10:17 PM
emoore924's Avatar
cheesie as it is....
J.C. Whitney has quite a selection...
Old Apr 6, 2002 | 09:15 AM
redmaxpa007's Avatar
i SeE what you did therE
that is where i put mine..
Old Apr 6, 2002 | 11:59 AM
Rufus's Avatar
i bought one exactally like the one you have in your pics. but how do i install it? i want to replace my horn with the air horn. it gave me instructions but all they really say is how to mount it. how would i go about replacing my shock horn with the air horn? and which wires are the ones to the stock horn? please be as deatailed as possible. and in your signature, the pic of your door, how and what did you replace the botom carpeted panel on you door with?
Old Apr 6, 2002 | 12:08 PM
in the instuctions, the second caption down, shows a single wire setup (what i mean is a single wire to the OEM horn) that is what you will use.
you do not have to cut the oem wire either.. it has the proper connector to install it directly.
the horns are mounted on a bracket i made by going to home depot. it was a 4-5 foot piece of metal that has holes in it. i found it in the section with the metal dowels. it cost like $2-$5.. i cut it to the desired height.. i mounted it directly to the OEM horn bracket.
Old Apr 6, 2002 | 04:38 PM
kenichi97SE's Avatar
air horns
I have the Hella triple air horns which I bought online at Autobarn.com I believe. They were pretty cheap, about $45. I followed the instructions from MEGAMAX in the readers rides section. I put my horns by the washer fluid resevoir and tucked the compressor between the fender and the washer fluid resevoir. I made some brackets from pieces I found at Home Depot. It's I tight fit but they work pretty good.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
