Corner Lights give off DULL YELLOWISH COLOR even with Hyper White Bulbs!!! HELP!!
Old Apr 5, 2002 | 12:42 PM
Moy's Avatar
Moy
Ok here's my problem!
I have purchased 2 types of HYPER WHITE Blubs for my corner Lights (1157 bulbs), one from custommaxima.com, the POLARG HYPER WHITE bulbs and one from AutoZone, some other brand which is also Hyper White.
BUT the color that they give off are still a DULL YELLOWISH COLOR, while the rest of my lights are a Nice Hyper White color??
I was thinking the Corner Lens were problem, but both are Perfectly Clear and clean when you look at them in the day??? Lens do not look dirty at all or yellowish?? Could it be the lens?? Any ideas??
On Custommaxima.com there's a link where you can make the corner lights brighter, but i dont think this could do it for me cuase its only to make them brighter , while my problem is that there a DULL YELLOWISH COLOR.
PLEASE SOME HELPPPPP!!!!!
Old Apr 5, 2002 | 12:47 PM
Cashj2002's Avatar
Re: Corner Lights give off DULL YELLOWISH COLOR even with Hyper White Bulbs!!! HELP!!
What year is your car?
HondaKiller718's Avatar
Do a search for rewiring your corner lights.
Also check www.maximadriver.com
carnal_c30's Avatar
Former Sponsor
I have the same problem, with my headlights being almost perfect HID, my corners look dull
When I had the Polargs the heated up so much they burnt themselves out but they looked good... now the ones I got now from Pep Boys WHAHAHAH APC look fockin green and nasty
but its such a pain in the *** to take the clearence lamps out I'll just wait awhile
Old Apr 5, 2002 | 01:58 PM
jc008's Avatar
I got Raybrig Hyper White and they look exactly like the stock ones. My PolarG are in the mail and I am hoping to see a nice hyper white color - even with a little blueish color to it, but hopefully not yellowish.
Old Apr 5, 2002 | 02:05 PM
MADMAN's Avatar
I just simply unplugg the lights. To me it looks better with HIDs.
Old Apr 5, 2002 | 02:23 PM
thezcarguy's Avatar
you guys should try the 1156 bulbs.. I have em in my car and they are very bright and match nicely. I have a pict in my sig of em.
Old Apr 5, 2002 | 03:11 PM
Sarah99GXE's Avatar
Maxima Princess
Can you buy these anywhere? Like Pep Boys or Kragen? I hate the yellow look to mine as well...
Old Apr 5, 2002 | 03:15 PM
jc008's Avatar
I thought 1157 was for the clearance (corner lights)
and 1156 for the blinker lights ?????
Old Apr 5, 2002 | 03:37 PM
carnal_c30's Avatar
Former Sponsor
1157 is a dual filament bulb incase, 1156s are single... both work fine 1157s are for the rear brake lamps....
getting nice bulbs is hard to do at the autoparts store.. thats where I got my current 1156s and the look green I have a set of Mercury bulbs from Japan I guess I'll put them in and see how that looks... otherwise go for Polarg or PIAAs.. PIAA Xtreme whites came out now! they look sweet!
Old Apr 5, 2002 | 04:32 PM
SilverMax98's Avatar
Are you saying that you can put an 1156 bulb in a 1157 spot ?? That would probally be alot easier than a rewire huh ? Is there any problems with doing that ??
Old Apr 5, 2002 | 04:42 PM
MJM97MAXSE's Avatar
Stealth Max has Some
Stealth Max, an Org Member has a good price on Piaa Extreme Whites.
His price is something like 12.50 Shipped to you in the lower 48 States. I have bought numerous items from him and his rep is very creditable.
These prices are so much better than local performance rip-offs...
Later,
Mike
carnal_c30's Avatar
Former Sponsor
I dont think there should be any problems I dont have any!
Old Apr 6, 2002 | 12:32 PM
Moy's Avatar
Moy
So Hyper White 1156 bulb's would solve my problem with the dull yellowish color??
So the problem is NOT with my corner lens???
If the 1156's bulbs are the solution, what type do i need?? Where can i purchase them??
Old Apr 10, 2002 | 09:45 PM
carnal_c30's Avatar
Former Sponsor
the only problem I can think of is the bulbs running at 27W (Ithink thats what the run) running very hot and causing some problems with the housing and the harness... usually i think the 1157s run at 8W thats why they are so dull...
and Moy just get any superwhite 1156 it mite not match but hey its a lil experiment... it takes some time to find something that matches perfectly
Old Apr 11, 2002 | 07:29 AM
JAY25's Avatar
I am a picky guy and my corners don t look yellow at all. You need to get the 27/12 Volt light bulbs shave off the top nipple and install them bacwards. why bother to rewire your lights when it takes a couple of mins to shave down a nipple on the bulb. Why shave the top nipple? the bulb is dual filament to let the 27V shine all the time since they are not blinkers, and they will look bluish white, but not bright like HIDS. With my purple HID lights my corners look somewhat green.
Old Sep 7, 2002 | 12:36 PM
Shugarhi's Avatar
does anyone know if this works for 3rd gen corners as well?
Old Sep 7, 2002 | 01:02 PM
Vyrus's Avatar
If they are dual filament and have one bulb higher than the other they yes it should. Go out and check it shouldn't take but a minute. Plus you could try it, cornerbulbs don't cost too much. Or you could try searching. BTW your car looks really sweet but you should put some eyelids on to cover up the gap ontop of the E36 lights.
-Cyrus
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Max8
Aug 20, 2015 07:20 PM
Viralkill
Aug 16, 2015 05:09 PM
