head lights problems
Old Apr 5, 2002 | 04:42 PM
sniperol's Avatar
i read some articles regarding the upgrade of the headlight harness. I did that since I keep getting my bulbs burn using the xenons.
Here's my problem now, after the the harness upgrade.
My right High beam is so dim, it work but very very dim. The low beam is OK
My right low beam any new bulb i put will burn the filament. The high beam is Ok,
Both have upgrade hardness. Do i have to upgrade the ground wires or rerun it? I think i over burn the wire using the xenon bulbs in the with the factor harness when i first got the car.
What should i do ? can anyone help me out?
Thanks.
1997 Maxima GLE.
Old Apr 6, 2002 | 05:47 AM
njmaxseltd's Avatar
Check your grounds. Make sure the connections are CLEAN! You have to be on fresh metal, not paint.
Old Apr 7, 2002 | 09:46 AM
sniperol's Avatar
I did not creat any new grounding. There were three wires and I just connect the new harness into the 3 original wires. Are you saying I should create a new grounding ?
Old Apr 7, 2002 | 10:38 AM
MaximaRacer's Avatar
What kind of harness did you get? The harness that most people have including, you just connect one of the headlight sockets into the harness and connect the new ground to the chassis for each side. Connect the ground to the fender screw. That is a good ground.
Old Apr 9, 2002 | 07:27 AM
sniperol's Avatar
I got some harness on ebay. It has three wires just like the original harness. I just connect them all in and it started to mess up.
Old Apr 9, 2002 | 08:56 AM
1MAX2NV's Avatar
Upgraded wiring harness suppose to come with separte relays and heavy duty wires to the battery. Check the link below.
http://suvlights.tripod.com//sitebui...ireharness.jpg
Old Apr 9, 2002 | 03:43 PM
sniperol's Avatar
so should i get a relay(s) and totaly rewire it just like the diagram ? Where can i find the relays, I can't any relays to buy at retail stores.
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
