All my lights went out!
Old Nov 24, 2000 | 02:42 AM
Joe's Avatar
Joe
I recently rewired my corner lights (did my fogs a while ago) and yesterday all my lights except for my headlights went out. My brake lights and turn signals still work, but none of my city lights will turn on. At first, I thought my connection came loose, but when I checked, everything was fine. So I thought, "I must have blown a fuse." But I checked all my fuses and they are all fine. So right now, I'm thinking, "What the hell is wrong with my lights??" I have no tails, corners, side-markers, or fogs. ...and no, all my bulbs did not go out. I checked them all by connecting the wire to the battery. Can anybody tell me what's going on? Any help? PLEEEEEASE...
Old Nov 24, 2000 | 05:39 AM
Daniel B. Martin's Avatar
Originally posted by Joe
... ...I thought, "I must have blown a fuse." But I checked all my fuses and they are all fine ... ... Can anybody tell me what's going on? Any help? PLEEEEEASE...
This does sound like a blown fuse, so perhaps you overlooked one. On a 4Gen Maxima there are two places to check fuses. One is the fuse block in the passenger compartment, behind a pull-out panel in the lower dashboard, left of the steering column. Another is the fuse and fusible link box in the engine compartment, adjacent to the battery.
Old Nov 24, 2000 | 07:56 AM
sx7r's Avatar
that happened to me when i was doing my lights too. i think the fuse was in the box next to the battery.
Old Nov 25, 2000 | 08:24 AM
Ants97SE's Avatar
I had this problem too, the corner lights are on the same relay as the Taillights, that's the fuse that blew, i believe it's a 5 amp fuse... change that to a 7.5 and you'll be all set.
Old Nov 25, 2000 | 08:43 AM
Originally posted by Ants97SE
... that's the fuse that blew, i believe it's a 5 amp fuse... change that to a 7.5 and you'll be all set.
Don't do this. The fuse is a protective device. If you change to a higher ampere fuse you are defeating the purpose. This could lead to bigger problems than a blown fuse.
Old Nov 25, 2000 | 09:47 AM
MardiGrasMax's Avatar
Happend to me too, except my fuse panel cover was not marked correctly!?!?! I put in the 7.5 amp about 3months ago and have not had any problems. Nissan didnt design the corners to be on the high filiment all the time either, but it works.
Old Nov 25, 2000 | 04:00 PM
Ants97SE's Avatar
I've had the 7.5 amp fuse for 5 months, no problems with it at all.
Old Nov 26, 2000 | 08:01 PM
Joe's Avatar
Joe
Hey thanks everyone. I changed the tail light fuse and everything is alright for now.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
