e-brake light
Old Apr 10, 2002 | 03:33 PM
Daddy Fat Sacks's Avatar
e-brake light
for the last day, when im driving my ebrake light stays on even tho the brake isnt pulled up
anybody know what this is?
Old Apr 10, 2002 | 04:26 PM
Iqb316's Avatar
Re: e-brake light
I had the very same problem a while ago. The reason the e-brake light stays on, is because you're low on brake fluid. Check your brake fluid, and if it's low, top it off. That's what I did, and the light didn't return.
Old Apr 10, 2002 | 04:46 PM
thanks, i'll check it right now
Old Apr 11, 2002 | 07:56 AM
maximus75's Avatar
Check your barke pads too. The reason the fluid goes down is because the pads are getting low and the calipers require more fluid to to make up the difference. That light severs 2 purposes. 1) E brake 2) pad life
Old Apr 11, 2002 | 08:25 AM
HondaKiller718's Avatar
I had the same problem a s few days ago, will check pads and fluid, thanx
Old Apr 19, 2002 | 05:03 PM
Tampa95GLE's Avatar
Me Too................
It happened to mine a few months ago. But my brakes are fine and fluid is fine. I've used the hand brake for all of my 82,578 miles. So I think and assume that the switch is stuck. It's small and cheap ( about $7.00 I think ). That will be my next approach. Now I have to figure out how to get the console off.
Old Apr 20, 2002 | 05:42 AM
tifosiv122's Avatar
My Ebrake light went off and I couldn't shut it. I opened the boot and looked in and saw one wire loose. It was hitting metal and thinking it was up. I fixed the wire and the problem went away.
Erik
Old Apr 20, 2002 | 01:51 PM
i put brake fluid and it hasnt come back on
thanks
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
