Wanna get frustrated? Change your PCV valve!
Old Apr 14, 2002 | 10:35 PM
FLO_BOY's Avatar
some posts claim 15 minutes to change their PCVs...DAMN IT!
this thing took me 1.5 hours for two simple reasons:
1) I kept dropping it/losing it in the engine bay.
2) the hose to attach it is WAY EASIER to get off than back on.
Hopefully, the only positive thing to come of this is, well, my new PCV, and a future write up with pics and tips to not be a spazz like me
oh, one quick tip -- don't do it in a mall parking lot assuming it'll be an easy 10 minute job (or when ppl are waiting for you... )
-FLO_BOY
Old Apr 15, 2002 | 12:19 AM
Chunger's Avatar
My other car is a Hybrid
LOL... Didn't you know you had to apply the X 6 factor when you do it the 1st time?
Old Apr 15, 2002 | 03:33 AM
Yossarian's Avatar
one word... lubricant
(this is where you slap your forehead )
try some mineral oil next time, generously applied in the case of the pcv - because that's a little ***** even when you're doing it right
Old Apr 15, 2002 | 03:55 AM
KWheelzSB's Avatar
I second this - with lube - took me 3 mins.
Old Apr 15, 2002 | 10:01 AM
pmg's Avatar
pmg
Old Apr 15, 2002 | 10:50 AM
Max4U's Avatar
Did mines in about 3 min. once you get the hose off twist and pull it up at the same time it will pop right out.
Old Apr 15, 2002 | 12:05 PM
SuDZ's Avatar
As far as dropping it in the engine I got sick of doing that and put it on like a 10mm socket. Then when it wasnt sliding in right I gave the socket on the extension a tap with a hammer. Went right in without a problem then.
SuDZ
Old Apr 15, 2002 | 12:10 PM
FLO_BOY's Avatar
Its a tight fit -- definitely.
I also "tapped" mine in -- the hardest part was then re-attaching the hose that connects it...next time (well, next time I'll pay ) I think that one should reattach the hose before putting the PCV back in its place.
FLO_BOY
Old Apr 16, 2002 | 09:23 PM
TooMAX's Avatar
SuDZ
Needle nose vice grips also work wonders... Took me longer to find the damn valve than to replace it!
Old Apr 17, 2002 | 06:46 AM
JAY25's Avatar
I have to change my PCV valve too, but if you dont have any lubricant here this will sound crazy get a little saliva from your mouth and that should lube it right up and the heat will evaporate it. At least thats what I did to push my fuel hoses back in. I will post and inform how long it took me to change my PCV valve. I already located it. right under the throttle cable area.
Maxboy23
55
May 1, 2025 06:09 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
tardrex
Sep 11, 2015 07:35 PM
I<3 A32's
Sep 10, 2015 11:07 AM
