Someone please help me with a clutch problem
Old Apr 15, 2002 | 06:38 PM
MaxedOut97SE
Hey everyone, I did a search, but it didn't really help that much, I need advice from some of you who know alot about cars.
Well, here's what's happening: after the car is warmed up, starting off gently in first, as I am about to release the clutch, the drivetrain shakes. It doesn't do it if I give it alot gas or start off fast. It only does it after the car has been warmed up. I had the clutch replaced about 10 months ago, and I have been extremely dissatisfied with it from the start. Like if you drive it hard, say one full throttle 1-2 shift, it will grab adequately (though not impressively), but immediately after only one case of hard driving it slips horribly. My old clutch w/ 65k miles on it was about 100 times stronger!!! (the only reason I replaced it was b/c they were doing tranny work and I figured why not save some money and replace the clutch then- I regret it now) I took it to the dealer a while back and they said there was nothing wrong with it. THey also said it was a stock OEM clutch, not a "key value". I really have no idea what the problem is. And I am really worried here because I am only 400 miles out of the warranty the dealer provides. I am hoping they will fix whatever is wrong, even though I am out of the warranty. Seeing as I have complained about the clutch from the start, they might take that into consideration.
Does anyone have and suggestions or info?
Old Apr 16, 2002 | 01:09 PM
MaxedOut97SE
C'mon, I know that someone can help me here....
Old Apr 16, 2002 | 01:17 PM
dwapenyi's Avatar
Shakes, as in shudders?? Maybe they didn't re-surface the flywheel?
DW
Old Apr 16, 2002 | 01:33 PM
MaxedOut97SE
DW
Yes, it's more of a shudder. If resufacing the fly-wheel is the fix, and it's something they didn't do, are they obligated?
Old Apr 16, 2002 | 01:38 PM
mike_rose's Avatar
i have the same exact problem minus the shudder. i hope you find some answers. i could use some too...
Old Apr 16, 2002 | 01:46 PM
dwapenyi's Avatar
Any good shop should do it anyway since the clutch was replaced. As for whether they are obligated to do it,
DW
Old Apr 16, 2002 | 01:47 PM
MaxedOut97SE
Yeah, the answer is: NISSAN CANNOT BUILD A TRANNY FOR ****!!!!!!!!
J/k, but not really......so your clutch slips bad too? Was it replaced?
Old Apr 16, 2002 | 03:12 PM
rmb's Avatar
rmb
Pressure plate needs to be replaced or resurfaced, flywheel should be looked at closely too for resurfacing.
They should have done it. Bring it back...
-RMB
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
