4th Gen Brake Squeal-any help?
Old Nov 26, 2000 | 10:08 AM
cyclemax's Avatar
After I disassembled (removed pads and clips) and painted my calipers, I'm getting an annoying brake squeal. It sounds like it's coming from the R/R. The pads are hardly worn.
I know there are thin, metal plates that go between the outboard pad and the caliper, and I think there was some anti-rattle stuff on the inboard pad. Maybe I need to re-apply after disassembly? Any ideas or info from service manual would be greatly appreciated.
BTW, calipers and rotors refinished very nicely, and look tight framed in the 18" Zenetti Valeos.
Old Nov 26, 2000 | 02:46 PM
Daniel B. Martin's Avatar
Originally posted by cyclemax
After I disassembled (removed pads and clips) and painted my calipers, I'm getting an annoying brake squeal. It sounds like it's coming from the R/R. The pads are hardly worn. ... ...
Brake squeal is annoying. Getting rid of it is half science, half black magic. Things you could try...
- Remove pads, use a hand file or electric angle grinder to bevel the leading and trailing edges of the friction material, re-install.
- Use emery paper to "rough up" the shiny surfaces of the rotors.
- Apply Blue Goo anti-squeal compound to the back of the pads.
Old Nov 26, 2000 | 04:10 PM
Black95Se's Avatar
Make sure your shims are on right and use break anti-squeel compound.
peace
Old Nov 26, 2000 | 05:19 PM
Chebosto's Avatar
RIceD OuT moDErAtor
my squeak too!.. really bad.
get some brake-goop. it's anti-squeal gel from pepboys.. don't know the name off hand, but it's in the "lubricants/sealants" section if i recall properly..
Old Nov 26, 2000 | 07:49 PM
got rice?'s Avatar
any PBC grease or a silicone-based grease on the shims should fix it.
Old Nov 27, 2000 | 06:48 AM
GregP's Avatar
Squeal can also be caused by new pads that were not properly bedded-in.
Old Nov 27, 2000 | 06:52 AM
Bernie Lomax's Avatar
Tomorrow
My guy put new pads and turned the rotors about 5k mi ago. They have been squeeking still ever since. It's going back tomorrow, and I will let you know what he does and if it works. I have heard people suggest plastic shims?
Old Nov 27, 2000 | 07:12 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Tomorrow
plastic shims will melt in a second.
if u can get the hardware kit from courtesy or any dealer. it comes w/ all the shims and springs. also use a quality pad. cheap pads tends to squeek a lot.
Dan
Old Nov 27, 2000 | 05:00 PM
kedeg97gxe's Avatar
HA HA I get to use the search
Squealing brakes
My 97 Max brakes squealed terribly and every time the dealer or mechanic checked them out they all said that i had 90% left. The mechanic said live with it after I tried two different brands of pads.I went to Nissan and bought their premium pads and lo and behold the squeal stopped.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
