Big Problems With My Max
OK IT ALL STARTED WITH HITTING A BUMP ON THE HIGHWAY AT ABOUT 80 MILES AN HOUR. IT TOOK A WHILE FOR THE TRANSMISSION TO GO OUT BUT I LOST DRIVE. TOOK IT TO THE TRANNY SHOP ON THE HIGHWAY IN SECOND GEAR DOIN ABOUT 65 MILES AN HOUR THEN THE CHECK ENGINE LIGHT CAME ON. WHEN I GOT IT BACK FROM THE TRANNY SHOP IT WAS STUTTERING REALLY BAD AND LESSENED AS TIME WENT BY.
I WAS TOLD TO REPLACE CRANKSHAFT POSITION SENSOR: DIDNT WORK.
CHECK FLYWHEEL: THAT DIDNT WORK. MASS AIR FLOW SENSOR: THAT DIDNT WORK. OXYGEN SENSORS: BOUGHT THEM BUT DIDNT FIT. I WAS ALSO TOLD THAT THE THROTLE POSITION SENSOR MIGHT BE IT, PUT A DIFFERENT ONE IN AND NOW I AM BACK TO REALLY BAD STUTTERING AND A VERY SLOW CAR.
PLEASE HELP.
THANKS AHEAD OF TIME.
PLEASE HELP.
Why don't you check the codes in your ECU before you go any further. They usually tell you what the problem is. Look at the stickies in the beginning of this forum to see how to get and read them from your cars ECU.
MAXSE5SPD
Sep 17, 2022 04:00 AM
FlaMark
25
Aug 28, 2015 10:15 AM
yat70458
Aug 3, 2015 01:16 PM
