WTF 1/4 times worse with Y & B pipe!!!
OK, before Y & B pipe I was running mid to high 15s. After Y & B, I couldn't break out of 16s. Made three runs the other nite, 16.098, 16.409 & 16.450. What's up with that? Am I getting too much air flow? No back pressure? Help!!
RR
RR
Re: WTF 1/4 times worse with Y & B pipe!!!
RR
RR
SuDZ
Re: Re: WTF 1/4 times worse with Y & B pipe!!!
Originally posted by SuDZ
Did you change the muffler with a Bpipe? To a straight through one or anything?
SuDZ
SuDZ
RR
Originally posted by theblue
have you reset your ECU.. have you changed anything else? how long have you had the parts on...
RR
I've had the parts on for about a month. Don't know about the ECU thing. Can you explain. Thanks.
RR
RR
BTW it is good habit to do this any time you make performance related modifications.
Originally posted by maxwillden
You have to reset the ECU under your dash by the gas pedal so it will relearn the new variables of the engine (also driving habits...)
After we reset the ECU how will I be able to tell the difference? Thanks for all your help, guys. You don't know how mad I was the other nite at the track. Thank goodness a couple of guys that I really wanted to race didn't show up.
RR
So just disconnecting the battery won't help like I've read in some other threads? Will print out the instructions and get hubby to help me. Honestly, I was ready to put the stock pipes back on and may still put the stock B back on just for the noise factor. I can't handle the loud noise. I'm going to put the stock muffler back on and if that doesn't help, you may see a B pipe for sale on the for sale forum soon.
RR
RR
Please post your before and after mph numbers, 60' times the split times.
RR
RR
In order to help you, I've gotta know some more numbers. Could be something as simple as changing your shift/launch rpms.
Same thing happened to me when I first got my Y... That was a while ago, but for a while I had the fastest auto 4th gen.
Re: Please post your before and after mph numbers, 60' times the split times.
After MPH 85.17, 82.51, & 84.10
all times launched at approx 2k RPM (I'm auto)
60 foot (before Y&B) 2.312 & 2.325
60 foot (after Y&B) 2.417, 2.423, & 2.593
I have to say, the best time I had (after Y&B) I went through the gears, just to see what would happen. That's when I got the 16.0 and I thought, to hell with that, I'll go back to just launching in Drive. Well, I did and that's when I got the two 16.4s!
Hope that helps.
RR
Sorry to hear about your times. It looks like you got a higher top speed w/ the new combo?? Did you get a lot of tire spin? Aside from that, much like everyone has stated - you need to reset the ecu. Here's a link w/ instructions, first check for any codes and then reset it. After it's been reset it will take a little while to "relearn" the operating parameters of the engine and how you drive. Hope this works for you - I have a y pipe somewhere in the mail and hope I benefit from it. http://forums.maxima.org/showthread.php?threadid=104931
The car runs fine during every day driving. It seems to me like it's quicker. At the track, I only got wheel spin on the last pass, which was my worst.
RR
You are running slower because of your horrid 60' times. To a point, trap speeds are unaffected by your launch, but if you spend EXCESSIVE amount of time spinning your tires, you are wasting time spinning when you should be accelerating. I am confident that if you turned identical 60' times as you had BEFORE the Y and B, your trap speeds would be at least 1.5 mph higher.
Do I use the same procedure even if I'm not getting the CEL?
RR
RR
Nealoc is correct, and I'd like to add a little more to his comments-->
Before MPH 84.62, 85.10
Hope that helps.
RR
Hope that helps.
RR
Your higher trap speed shows that you are making more HP, but as Neal said, your horrible 60' time is killing you. With the Y-pipe and B pipe, you may notice that you have a stronger top end, with a slight weakening of your bottom end. What I can do is offer you some advice, it worked for me, and a few others I've coached a while back.
1. Whenever possible, let your engine cool off before and between runs. Let it cool as much as possible with the hood open. I've found that auto 4th gens are much more affected by engine temp than their 5 spd brothers. My car would fluctuate ats much as .3-.4 with no other difference other than the engine temp.
2. Launch. 2k is too high to launch at. My experience's (and timeslips) show that the best launch comes at a mild 1000-1000 rpm launch, which will flash stall the convertor, and get you much better 60' times. How much better? With my Popcharger and stillen Y (and HKS muffler) I would routinely pull 2.21-2.28 60' times. When I changed to 16 inch wheels, I was pulling 2.18-2.20 on each run. My best 60' times were just before I stopped racing, and I was pulling 2.10-2.15.
Simply hold the rpm's steady at 1000-1100, and on the last yellow, stuff the throttle. You should launch with just a hit of wheelspin, and your 60' times should be in the high 2.2- low 2.3 range. Each .1 at the start can be worth up to .2 at the top end of the track.
3. Shifting. With an intake and Y, you would need to move the shifter at 5500 rpm. This will get you a full throttle upshift exactly at 6k. Keep in mind, that if your engine is hot, you won't be making any power at the big end of the track, and your et's will show it. I had about 100 runs on my 95 GXE, and it got to the point I could predict my et's based upon how hard the car pulled in 3rd gear.
Let the engine cool down between runs (so that the temp gauge is below its normal position) then pull into the staging lanes. By the time you get to the tree, it should just be reaching normal. Launch as I described, and you should see some definite improvements.
Re: Nealoc is correct, and I'd like to add a little more to his comments-->
Thanks jimbrowski. That's alot of good info. I will try your technique.
RR
That's correct
So you're saying I should not start off in Drive, but go through the gears? You guys have been great to help a novice girl out. I really need to get this figured out. There are a couple of smart *** guys dissing the "grocery getter" and I really need to shut them up!
RR
RR
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
