tachometer issues
tachometer issues
Does anyone know where the stock tachometer gets its signal? Is it from a computer? Where is it located?
I seem to have the same prob a lot have had in the past regarding a tach that does not indicate engine RPMs, but rather slowly creeps up to redline over the course of 25-30 minutes, even though the engine is fuctioning normally.
It looks like a classic grounding problem, but I have no idea where and I'd like to think its under the hood rather than behind that dash that will take 5 hours to remove!
Has anyone who had this problem found a solution? The Haynes manual is worthless in regards to describing the tach system, and this is my first computerized/fuel injected vehicle!
Thanks all
Mike
Thanks all
Mike
Re: tachometer issues
Thanks all
Mike
Thanks all
Mike
Re: Re: tachometer issues
Originally posted by MIXXMAX
Don't quote me on this, but I believe the tach receives its power from the BCM (powertrain computer) located on the front passenger floor behind that small black kick panel. I'm not sure, exactly, what color wire it is...but I'm almost sure this is where the power is located. I know this, because, when I used to have a remote start, this is where they "tapped" into to control my RPM's when the car was remotely started. I hoped this helped any.
MR2 T'd
Jul 9, 2021 05:06 AM
Mar 12, 2020 12:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
BrandonCause
Sep 14, 2015 10:41 PM
