My car is leaning!! HELP
Old Apr 23, 2002 | 09:00 PM
QuEeNz MaX KiD's Avatar
Hopefully someone can help me out on this one.. I have a 98 SE 5spd.. the car is about half an inch lower on the driver side of the car.. no one notices but it drives me crazy!! The car rides fine and nothing seems to be wrong.. Has anyone had this problem or know what it might be???
HoLLa BaCk
Old Apr 23, 2002 | 09:27 PM
The_Bomb's Avatar
Re: My car is leaning!! HELP
HoLLa BaCk
Blown strut???? check the side that is leaning and see if the strut is "hairy" around the silver part. if it is then you need to replace it.
Adam
Old Apr 24, 2002 | 05:48 AM
njmaxseltd's Avatar
Re: Re: My car is leaning!! HELP
Adam
Struts have nothing to do with ride height.
Are you parked on an even surface? Springs are the only thing that effect ride height. Are you on stock springs or after market? Has any suspension work been done on your car? If so, was it done correctly? Check all strut mounts to see if there worn out. Also strut mount bushings may be worn out. The bushing is a thick 1/4 inch rubber isolator that the spring sits on. If thats missing or worn out, you may ride lower on that side, only by 1/4 inch or so. You should also be experiencing lots of noise if thats the case.
Old Apr 24, 2002 | 06:36 AM
95emeraldgxe's Avatar
yeah - dun do it in your car!!! - i got a group deal goin on with lowering springs =]
Old Apr 24, 2002 | 09:31 AM
Re: Re: Re: My car is leaning!! HELP
I always park on an even surface.. There is no noise at all and the ride is fine.. its 1/2 inch lower on the front driver side and a little less than 1/2 inch on the rear driver side.
Old Apr 24, 2002 | 10:11 AM
Keven97SE
Some things to check: A mis-alignment of the front wheels can lead to a slight leaning, as can a blown strut mount (top of the front or rear struts).
HoLLa BaCk
Old Apr 24, 2002 | 12:12 PM
rmb's Avatar
rmb
HoLLa BaCk
Maybe that 400 pound dead chick in your trunk has rolled to the drivers side?
-RMB
Old Apr 24, 2002 | 03:12 PM
mike_rose's Avatar
i think that your springs are sagging and it is time for them to be replaced
Old Apr 25, 2002 | 08:30 AM
KWheelzSB's Avatar
Got a good set of OEM springs 4 sale CHEAP!
http://forums.maxima.org/showthread....hreadid=112935
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
