Timing Cover Oil Leak
Old Apr 24, 2002 | 10:42 PM
NISMOPower's Avatar
Has anyone had this before????? Everyone i've talked to never seen this happen before....Dealer said someone pushed the car too hard.....quoted me for $1200 to repair....advice???
Chris
Old Apr 26, 2002 | 06:46 AM
rmb's Avatar
rmb
Re: Timing Cover Oil Leak
Chris
That's a b!tch to repair... That price seems a little high but don't they all... I sure wouldn't want to do the job.
But I've never heard of a Max leaking there.
"Pushed to hard"? ..... And made a leak in the timing cover? Ummmmm.... I don't think so.
-RMB
Old Apr 26, 2002 | 07:02 AM
JAY25's Avatar
Re: Re: Timing Cover Oil Leak
The dealer told me the same thing I need to get my repaired prior to me leaving New Orleans and they said it was a $1200 job. So out has to come the supercharger in about 3 weeks and I have to take it to them and get that repaired. Also they told me if there was something I wanted to replace any performance part to give it to them and theyll put it on since half of the engine has to come off. All I am paying is $50 for this job and the other $1150 the warranty will cover.
Old Apr 26, 2002 | 09:29 AM
NISMOPower's Avatar
That's one problem...I don't have any warranty on it....what should I do??????? the other day i had to put an extra qt. or oil because of the leak...does anyone know what causes it?
Chris
Old Apr 26, 2002 | 11:21 AM
Maxwell's Avatar
Chris
The gasket has gone bad. The reason it costs so much to fix with 35 cents woth of liquid gasket is that it takes HOURS to get to it.
Try buying high-temp liquid gasket at a car parts store and smooshing it into the seam where your leak is. I have this problem, and have slowed it to a tiny dribble by doing that. One coat of liquid gasket over the seam and the surrounding cover (to prevent creepage), then some J-B Weld over the entire thing, all the way out past the liquid gasket. Then liquid gasket over all of that. It's better than $1200, I'll tell you that.
Old Apr 28, 2002 | 09:30 AM
NISMOPower's Avatar
i don't even know where the timing cover leak is????
Chris
Old Apr 28, 2002 | 11:56 AM
Mishmosh's Avatar
Chris
Me neither. On my 95, I do notice that right above the oil dip stick, there is some oil seepage. Maybe I'll clean up that area and try the sealant trick. I probably add a quart every 5k, so I'm not that worried.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rtirbany
Sep 8, 2015 11:46 AM
acw
Aug 13, 2015 12:50 AM
