Starting problem.....trying to find porblem....
Old Apr 27, 2002 | 05:25 PM
NISMOPower's Avatar
I need help finding where the problem problem of my car is....We just replaced the old alternator and battery with brand new ones....From what I I know we installed them all correctly....As for right now the car will crank...kind of slowly but will not turn over.....from what i know the car will crank very slowly....before the new parts the battery died twice after every recharge....it seems like something is draining my battery....well the problem coudn't be dead battery cause we just replaced it with a brand new one....costco brand...electrical connection maybe but i don't know where to check like every connection...where should i check....i've only checked the connections like the starter and battery....maybe it is the starter motor, or maybe the starter solenoid....before the new parts car wouldn't start not even crank....only when the battery was full.....tell me if you guys need more info.....
Chris
Old Apr 27, 2002 | 05:57 PM
nadir_s's Avatar
vicodin ... gift of life
Well, when u put in the brand new battery, did it crank and start right after?? if this problem happens like... within a couple hours or overnight it definately means you have a power leak... meaning your battery is grounded somewhere. i suggest you check every wire coming out of your positive terminal and make sure that it is not touching the body of your car. I had this problem once, and found out that my battery harness (metallic) was up against the positive terminal.
Old Apr 27, 2002 | 05:58 PM
gtr_rider's Avatar
192.168.1.1
Its the start bro, jesus. You shoulda told me all that info, sheesh
tsi6001
Oct 3, 2022 10:23 PM
jholley
Aug 30, 2015 06:39 AM
305head
Aug 26, 2015 09:03 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
