> Max Stalls...wt....? <
Old May 1, 2002 | 03:26 AM
MAX95RUS's Avatar
My MAX stalled this morning, again, as soon as I stopped at a STOP sign, and didn't start quickly too , but when the car warmed up, it seemed fine. MIL light didn't come on.
This problem started a few days ago for the first time. About three weeks ago I replaced Knock Sensor and PCV valve, cleaned Throttle Body (MAF sensor was clean). I USED search function..., maybe someone has some new info/update in order to solve this problem
Don't let your bro down ,
Thanks guys, I appreciate it.
Old May 1, 2002 | 05:46 AM
njmaxseltd's Avatar
Fuel Filter
Idle Air Control Valve - Might be lazy, you can clean it out just like the throttle body. You have to remove it and disassemble it.
Idle speed adjustment? Check the default settings. Without the TPS connected you should idle at around 700. If your way to low, the IACV is working overtime to keep your car idleing correctly, combine that with the face that it may be lazy, and there's your stalling issue.
Old May 1, 2002 | 07:41 AM
JeepRage's Avatar
could be another case of the Coolant Temp. Sensor. Search for it and check up on it. I had a good post about it 7 months ago or so. My car had sort of similar probs.
Goodluck, Hall
Old May 1, 2002 | 08:03 AM
bbrown's Avatar
Goodluck, Hall
I have a 95gxe and had the same problem, my max would just shut off with out notice and start back after a few tries(embarrassing at stop lights), get the coolant temp sensor replaced, the part only cost about $40.00(about the same size as a spark plug) and can be done within a 1/2 hour. I got mine replaced, no more problems.
hope it helps.
Old May 1, 2002 | 01:54 PM
MAX95RUS's Avatar
That's it! I am going to get a new coolant temperature sensor!
Another thing I noticed today, when car was warming up in the morning, fans would turn on and off for a few seconds
Old May 1, 2002 | 02:00 PM
bbrown's Avatar
my max did this also each time I started it. Replacing the coolant temp sensor will fix all this.
bbrown
Old May 1, 2002 | 02:01 PM
SuDZ's Avatar
Originally posted by njmaxseltd
Fuel Filter
What do you clean it with? Any type of cleaner or just a rag?
SuDZ
Old May 1, 2002 | 02:21 PM
NISMO808's Avatar
did any of you guys have a hard time starting from a cold start. Meaning the engine would just turn and turn but no start. Someone said it could be a camshaft position sensor problem.
I had this problem in the past in which the car wouldn't start on certain occassions like described above. And then other times I would come to a stop and watch my idle go lower and lower, the car would shake like it was going into rough mode and then finally stall.
Your right though, it is embarrassing when ur car won't start up for after a couple minutes. And your stuck there. Especially in rush hour.
Old May 1, 2002 | 08:54 PM
MAX95RUS's Avatar
Re: > Max Stalls...wt....? <
UPDATE!!!
Replaced coolant temperature sensor - $28 total
Took my Max for a test-drive and it didn't stall
Checked fans, they didn't turn on while car was warming up. When car warmed up, both were spinning.
Well, will see what happens, I hope replacing coolant temp. sensor solved this stalling problem. If Max will stall again I'll let you know.
What do you think guys, should I reset ECU just in case?
Thank you all for your replies!
Old May 1, 2002 | 10:29 PM
Jepht20's Avatar
Custom User Title...
Re: Re: > Max Stalls...wt....? <
howcome you got your part so cheap? i payed 41.03+tax so it was like 43...that's a pretty big difference in price for one lil part don't you think?
Old May 2, 2002 | 03:19 AM
MAX95RUS's Avatar
Re: Re: Re: > Max Stalls...wt....? <
Well I don't know This is how much I paid. I bought it from NISSAN.
Old May 2, 2002 | 08:23 AM
bbrown's Avatar
Re: Re: Re: Re: > Max Stalls...wt....? <
I paid $40.00+ for mine as well, whatever, as long as the max is running smooth and I don't have the headache of the problem reoccuring I am satisfied.
bbrown
Old May 2, 2002 | 10:07 AM
Jepht20's Avatar
did you guys put them in yourselves? if so, was it easy? i'm going to attempt to do it this weekend and it doesn't look like a complex part...so hopefully it's fairly easy. thanx for any suggestions
Old May 25, 2002 | 04:29 PM
cmac95gxe's Avatar
Maximaniac
I'm having the same problem too. I was at a light on sunrise highway today checking out this cute chick next to me in an eclipse and my car just stalled! I was soooooo embarassed! It started up after the second try. It kept stalling on me the whole way home. That is one of the worst feelings in the world. I'll replace the sensor and let everyone know if it worked. I really hope it works. Thanks everybody.
Old May 29, 2002 | 01:19 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
My SE simply idles around 500 rpm in D, sometimes as low as 400 rpm, any causes for such an oddly low idle?
This is a '98 SE w/ Auto. Trans and 75,000 miles
Old Aug 16, 2002 | 06:28 PM
Rooster286's Avatar
Just wanted to add another "yep, had all those symptoms, and yep, it was the coolant temp sensor".
48.50 installed for me @ a local mechanic
Old Aug 16, 2002 | 08:13 PM
Nismo3112's Avatar
Custom User Title
[B]Fuel Filter
Idle speed adjustment? Check the default settings. Without the TPS connected you should idle at around 700. If your way to low, the IACV is working overtime to keep your car idleing correctly, combine that with the face that it may be lazy, and there's your stalling issue.[B]
I see you have an SE-L..I have one too and my IAC valve looks completely different from any others ive seen...What does YOURS look like?? Im soo confused cuz i need to replace mine..and im trying to find one used, but none of them look like the one i have
Old Aug 17, 2002 | 03:46 AM
Monil's Avatar
Is that have a nice day cafe in St. Louis by any chance?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
