Fog Lights out...
Old May 1, 2002 | 09:35 AM
97MaxSE's Avatar
Fog Lights out...
Help....both my fog lights are out. I tried to replace them the other day but it is impossible. Anyone know what to do here? How much would it cost if I took it to a shop to get done? Your help is appreciated.....Thanks.
Old May 1, 2002 | 09:52 AM
pocketrocket's Avatar
Re: Fog Lights out...
Both fog lights are out = burnt out or not working?
1) Check the fuse in the F/L holder (engine compartment driver side).
2) If fuse is ok & you suspect bulbs are both blown (strange, but possible).
I don't know how different the 97+ is from the 95.
On a 95-96, there is a fake inner piece to your fog lamp. Push upward, it should unlatch and you can take it off exposing a bolt. Don't use a screwdriver.
b) Remove the bolt, and then 'yank' thr entire foglamp housing out. The other end is secured with a knuckle similar to the clearance lamp so if you've taken one of those out before, you'll know what I mean.
c) Undo connector, there is a lever inside that holds the bulb in place.
The rest is a bit sketchy but once you get the housing out, you should be able to figure it out.
Old May 1, 2002 | 11:54 AM
fast97maxse's Avatar
don't take it to a shop
it's really easy
use philips to unscrew plastic cover
then I think a 10mm socket to undo bolt
the light will come out easily
but I'll bet it's the fuse like pktrkt sez...
Old May 1, 2002 | 12:01 PM
breaux124's Avatar
http://integra.vtec.net/geeser/megamax/
More specifically:
http://integra.vtec.net/geeser/megamax/foglight.html
But check your fuses first, usually both bulbs don't blow at the same time without something else being the problem.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
