help - engine shakes at low rpm's
Old Apr 10, 2009 | 04:38 PM
  #41
Jgamble317's Avatar
Saaame prob...
Originally Posted by NmexMAX
WoW, jut tap the top huh? I need to do that today, because I have a stutter/hesitaion type of deal when I accelerate, and a bouncy idle.
BTW, Nick, if you find it to be the MAFS and don't have the 500+ dollars to buy the part from nissan, try thepartsbin.com, they sell it for 200, but if you want to to try a used part, try car-part.com, I found one on ther for 35 dollars
I've got the sammme prob. ive gotta change the knock sensor because its really bad. its even starting to do it at higher rpms of 4 and 5...
Old Apr 11, 2009 | 07:56 PM
  #42
pmatos's Avatar
this is just an update, not able to find a my mechanic to check into the injector #5 yet but my wife told the engine line was flashing from her last use of the car today and the O/D light come on as O/D off. this light was steady on.
The car i now parked. I will check the codes again tomorrow just to make sure everything else did not go wrong. I am think this has to do with the Knock sensor as the code 0304 is present.
Old Apr 11, 2009 | 08:14 PM
  #43
pmohr's Avatar
No more Maximas...
The KS won't cause any real engine operation issues, certainly not misfires.
Old Apr 11, 2009 | 08:30 PM
  #44
pmatos's Avatar
Will the CEL flashing cause any issues?
also what you think about this injectors for sale? it seems the guy has been selling parts from a wreck maxima and gotten positive feedback
http://cgi.ebay.com/ebaymotors/Nissa...ayphotohosting
Old Apr 11, 2009 | 08:31 PM
  #45
pmatos's Avatar
I heard that the misfire could cause the Knock sensor to go off, not sure if that is true or not, but I will have injector tested then the Knock sensor.
Old Apr 11, 2009 | 08:37 PM
  #46
pmohr's Avatar
No more Maximas...
Yes, the flashing CEL indicates a severe misfire. If it's dumping raw fuel, it could quickly and permanently damage the converter.
It's a great price...if you don't include the shipping, that's more than the parts themselves.
But if you price it out it's about $10 per injector shipped, which isn't too bad.
Old Apr 11, 2009 | 08:59 PM
  #47
pmatos's Avatar
True Thank you!
Old Apr 11, 2009 | 11:53 PM
  #48
Aneyehillateher's Avatar
Update on my issue as well. everything seemed fine until last night. was driving and suddenly idle was insanely high (4k). turned car off. let sit for about 5 mins, turned back on, and CEL came back on. drove it home with no problems. today I turned it on, and it started dropping rpms in d and r and nearly stalling until warmed up. gonna change out all spark plugs and remove TB to clean inside and out as well as IACV. (getting gaskets from dealer). Also going to run a bottle of fuel system cleaner thru it. Hopefully that works. Oh, and Im'a clean the MAF. Any other things i should try?
Old Apr 12, 2009 | 08:20 AM
  #49
pmatos's Avatar
You may want to run the codes again and see if anything changed because at first mine was throwing 0304 and 0707 but then 0604 misfire Cylinder#5( couple days after)
Old Apr 13, 2009 | 12:28 PM
  #50
bxclark's Avatar
My 99 maxima is shaking on idle at about 500rmp. I have gotten steady and flashing ce and oil lights. I have all new coils and ngk plugs that I will put in as soon as the coils get delivered.. I guess if that doesnt work then the fuel injectors are next.
Old Apr 13, 2009 | 01:23 PM
  #51
Ran the codes again. Only show the 0707 so still no misfiring. got the gaskets today to do the TB and IACV cleaning and putting in some NGK iridiums. (had platinum before and for like...ever) Hopefully that will do it. Cleaned out injectors to using one of those fuel system cleaner additives and some octane booster. (My brother's method of choice.) Will post results in a few days for bad or, hopefully, good.
Old Apr 15, 2009 | 07:50 AM
  #52
bxclark's Avatar
I will preface this with: keep any sly or negative comments about this topic being posted before to yourselves. If you can help please do and thank you.
Just bought a 99 Max with a little over 75k miles on it. The problem is at low rpms (500 - 1000) and at idle the car shakes and shudders. It does not happen in park just when I am on the brake. I am aware that this could be a coil problem and have ordered 6 new ones and some NGK plugs. If this doesnt fix the issue I would assume its the fuel injectors. The strange thing is that my oil and check engine lights comes on once in a while at the same time. Also if I hit the gas hard they will both start to flash. I checked the code and it is a cylinder 1 misfire. I have heard other people have this problem but I have not heard anyone have both the oil and CE light flash. What would any of you do in this situation? Please advise. I heard that driving the car like this can damage the catalytic converter. Is this correct and is so, why?
Old Apr 15, 2009 | 08:02 AM
  #53
pmohr's Avatar
No more Maximas...
Yes, the misfire could damage the converter. If it's a spark problem, you're dumping raw fuel into the exhaust, which will destroy the converter.
I'm assuming you've checked oil level? Have you checked the harness connector to the OPSU?
Have you ohmed out the injectors?
Old Apr 15, 2009 | 08:16 AM
  #54
bxclark's Avatar
First, THANK YOU for your response.
I recently bought this car maybe 3 weeks ago. When I drove it off the lot it studdered so I brought it back. The guy then changed the plugs and said it had sat for a while so to put premium gas in the tank. I figured he put some cheap plugs in there. Drove it off the econd time and same thing so I brought it back and he got the fuel injectors cleaned. Drove it off third time and it ran fine for a day then same thing. I got an oil change and put some additive in the oil. I never noticed a leak or any oil anywhere so I assumed the oil level was fine. I will check when I get off work. I will check the harness connector as well. I just want to know what the plan of attack should be as I want to get this car 100%. Thanks for the pic by the way. Just to confirm, cylinder 1 is the first one on the left... correct?...
Thanks again.
Old Apr 15, 2009 | 08:21 AM
  #55
pmohr's Avatar
No more Maximas...
Thanks again.
Cylinder 1 is rear bank, far right:
Old Apr 15, 2009 | 08:39 AM
  #56
bxclark's Avatar
Forgive my lack of knowledge. You say it is far right but the picture shows rear left. I am alittle confused. If I am facing the front of the car how does this diagram relate to how the engine is positioned. Based on the picture and where it is saying front is I would never think that it would be rear right. Thanks in advance.
Old Apr 15, 2009 | 10:29 AM
  #57
pmohr's Avatar
No more Maximas...
If you're talking about just looking at the engine bay from the front, then yes, it'll be to the left. The proper way to refer to it is on the right, though.
The front points towards the front of the engine, where the belts are.
Old Apr 15, 2009 | 11:17 AM
  #58
cab's Avatar
cab
Our 95 Maxima had similar symptoms and sure enough it turned out to be a bad injector...classic misfire puff, puff, puff at tailpipe, etc. Of course it couldn't have been one of the three EASY to get to injectors, no had to be one of the ones under the intake. Because the car was so old already I went ahead and replaced all three back there just because I didn't want to remove the manifold twice if the others were near failure (note: only the one injector failed the simple ohm test in my Haynes manual). It isn't a horrible job, but you do need to get the gaskets ahead of time in case you have trouble locating them. I tossed the other two old (but still good) injectors on the shelf in case one of the front three dies - I'll just toss one of these on. During my triaging I replaced a coil as it seemed to make a slight difference on one of the cylinders, but that was really a false lead.
Old Apr 15, 2009 | 11:30 AM
  #59
bxclark's Avatar
Thank you very much. This was extremely helpful.
Old Apr 15, 2009 | 07:04 PM
  #60
Update: CEL came back on still rear heated o2 sensor. since I don't have the $$ for a new one, my brother suggested doing a resistor mod to it. I searched and couldn't find a how to or even what resistor to use. anyone ever done this? Feel free to flame my newbieness Thanks in advance!
Old Apr 15, 2009 | 07:12 PM
  #61
pmohr's Avatar
No more Maximas...
Have you tested the sensor or the harness yet? Even checked to see if it's plugged in?
Anyway, search 'O2 sim'.
Old Apr 15, 2009 | 07:26 PM
  #62
Yea, my brother tested it, sensor is bad. harness is coo. Thanks for response. You sir, are the man
Old Apr 17, 2009 | 08:19 PM
  #63
Oh yay. got rid of the other codes. rear heated o2 is gone...2 days ago cel popped up again. ran the code..0505 which is no problem found...cleared it...today popped up again, checked again and got 0503 which is front right heated o2 sensor. Seriously this is going to cause my brain to explode. My bro checked the sensor/harness for it and both are good. though we initially thought rear was bad but thats gone away (i think in part to spraying a can of TB cleaner into the plenum) Is it a common thing with 4th gens for the damned o2 sensors to freak out like this? also, currently running 10/40, why i don't know, but could that be causing/contributing? Should I change the oil to 5/30? or 10/30 since its got 192k on it? current oil been in there maybe 1k miles... As usual, feel free to flame me, just make sure to hide some help in the flame Thanks
Old May 21, 2009 | 12:04 PM
  #64
maxi23's Avatar
I have the same problem... I changed out..KS, Injectors, Coils, and Plugs.. and still no difference.. =( Its a cyl.5 misfire. I think the cyl is completely dead as the plug is not red or hot after running the car for a few minutes. ANy ideas??? please!!
Old May 21, 2009 | 12:07 PM
  #65
pmohr's Avatar
No more Maximas...
Have you not done a compression test yet? Tested to see if the coil or injector are even getting power on that cylinder? Tested continuity on the harness? Checked the harness and connectors?
Basically, done any diagnostics other than throwing parts at it?
captchaos
Mar 15, 2016 12:18 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
dcardello
Sep 3, 2015 11:44 PM
