clear/red tail lights???????
Old May 3, 2002 | 01:56 PM
RI-Max's Avatar
can some one tell me whats the different in the tail lights.some brake lights are on the top and some are on the bottom??????? anyone know the differance?in years etc. cause i don't like the brake like on the bottom and also how do u clear them out?(make them red clear?)
jeff
Old May 3, 2002 | 02:43 PM
SuDZ's Avatar
do a search for red/clears there are many methods you can use
http://forums.maxima.org/search.php
SuDZ
Old May 3, 2002 | 03:20 PM
Conrad283's Avatar
I need a truck
Re: clear/red tail lights???????
jeff
97-99 brake on top, turning signal on bottom (can be cleared out)
95-96 brake on bottom, turning signal on top (cannot be cleared out)
if you have a 97-99 you can go to maximadriver.com --> how2 --> cosmetics --> red/clear
if you have a 95-96 you have to find all clears (very hard to find) and have them painted .. if you want DavidL is doing a group deal for the 95-96 red/clears ... he does a fantastic job
Old May 3, 2002 | 03:25 PM
choclatemax's Avatar
You can get all clears for the 95-96 at nopionline.com
Old May 3, 2002 | 03:50 PM
bidnizman's Avatar
You can't get all clears at Nopionline.com, those are discontinued and you will most likely have your order canceled if you try. Just like the Pacesetter STS is on Nopi but no available. Also, 95/96 tails CAN be cleared out, same way that 97-99's can. Do a search.
Old May 3, 2002 | 03:52 PM
Conrad283's Avatar
I need a truck
i'm was under the impression that they couldn't be cleared out because the amber in the tail light is the plastic and not just an insert ... hmmmm
Old May 3, 2002 | 03:57 PM
bidnizman's Avatar
There have been a few threads saying that the plastic can be pulled out just like the other lights. hmm, now I'm doubting myself, see what you've done? I'll check it out.
Old May 3, 2002 | 04:21 PM
Conrad283's Avatar
I need a truck
sorry didn't mean to confuse you ...
Old May 3, 2002 | 09:36 PM
taggate's Avatar
hi, for the 96-97 the amber can not be pull out cuz its one piece. the 98-99 the amber are separat piece so you can pull it out easlie. hope this helps. if you need infro to do this job i can help cuz i did my recently. total time to do it is about 1 hours.
Old May 4, 2002 | 07:50 AM
RI-Max's Avatar
alright guys thanx i was sooo confused lol
Old May 4, 2002 | 08:06 AM
clee130's Avatar
No you can't.
Old May 4, 2002 | 09:50 AM
97MaximaSE-L's Avatar
The 96 and 97 tails aren't the same. The 95 and 96 can't be pulled out, the 97-99 can be. This is simple stuff, CMK (common maxima knowledge)
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
