Blue LED behind Gauges for 98-99
i finally found a way to get some 194/168 bulbs in the gauges for 98-99 maximas. It took some cutting and some shaving of the LED's but it worked and it looks great. Once you cut the LED's they fit right into the stock sockets for the lights.
Go to my home page and scroll down to see the way they look.
Homepage
These are the gauges with the LED's in them, i really need the RED neddle kit now.
Homepage
Originally posted by taggate
hey there, it looks kool. could you do a write up ?
http://www.geocities.com/amixam69/nissan/dash/
very nice!
Please make a write-up / how to do for this! I know not all of us 98-99 owners want to have to resort to indiglo's...
BTW, in case anyone doesn't know.... the gauge clusters in 98-99 maximas are different from 95-97 maxes.. We have a freak size bulb back there that no one makes, so we can't just swap bulbs like everyone else..
Re: Blue LED behind Gauges for 98-99
Homepage
Homepage
What brand of blue lights did you use? Most of the ones I've seen are not that blue. I like.
ive done this to my 97 SE, and it looks great, except one of my blue bulbs has already faded to purple, but it still looks cool....i have another write up, which doesnt make you go into the fuse box or remove the steering column
Is it bright at night??? looking at the pics, they look very dark...
yes, u shud get the red needle kit, that will look hot, or u can get the blue needle kit, but u will have to paint/replace your needles to do that.
peace
peace
where can we see this write up?
Also, is that a 95-96 grille on your 97 year max in your sig???? did it fit with no problems? looks very nice..
geo... please elaborate on the process for us
Instructions are easy, just take out your gauges and take out the four sockets and bulbs(black) that illuminate the gauges, also take out the one for the digi odo(blue). Now the LED's that I used are from autodynamoc.com and they come in a plastic housing that can be sanded down to decreases the diameter of the LED so that it could fit in the holes.
these are the LED's i bought:
http://209.87.151.155/detail.asp?PRO...4-168-LED-Blue
If look at the picture the round tab is gone and the piece that you slide in has been cut to fit in the socket for the old bulbs
This is the LED as it sits in the socket. I did a trial and error strategy till i got the size small enough to fit the holes. And that’s all. Just put every thing back together.
The only problem is the they are not really bright so the needle do not illuminate very bright and its hard to see them at night, but that’s what a needle kit is for. Also the redline doesn’t show up.
Let me know if this makes any sence.
they are not very bright like the VW, but it looks really good, however the nededles barely show so its a bit tought too see, thats why i want to get a needle kit, rig some more LED's to light the needles up better.
As for instructions, it just like i said before, take the gauge cluster out, modify the LED's and plug them into the stock sockets. If you have specific question let me know and ill try and answer them.
Check out maxima driver for instruction on how to take out the gauge cluster.
do you know what size those LEDs are?
here are some very bright blue ones (5mm) but i don't know if that is the right size...
http://www.eled.com/SearchResult.asp...tegoryName=5mm(T1-3/4)
Also try www.lc-led.com for LEDs...
Any idea why they blew out? Sounds like too much current. What voltage does the socket provide, and what voltage were your LEDs? Most red/green/yellow/amber/white LEDs are 1.5~2.5v, blue LEDs are usually 3.5v~4.5v. Feed 'em 5v and they'll die or blow up.
i just bought the 2200mCd blue leds on that page. Can't wait to try them when i get them. They should be extremely bright!
but they are not the same leds as used by geo1317
his leds are bigger. I have a pic of those since i bought them a while back. hmm i'll try and post a pic.
http://www.geocities.com/multiplexor...es/BigLed1.jpg
Heres a link to a page i made. I dont think the above images will popup.
http://www.geocities.com/multiplexor...ma/BigLeds.htm
cool. post pics when you get them in and tell me how they work out. i'm interested in doing this myself...
they are the brightest blues i've had the chance to get my hands on. I hope they are really bright!
go to http://www.AutoDynamic.com and those are the LED's i used so they are not a standard 3mm or 5mm size. Also they are already wired for 12v application.
tarun900
19
12-20-2021 06:57 PM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
