People with Fiber Images C/F hood!
Old May 6, 2002 | 07:37 PM
maximus75's Avatar
I was installing a shock and glass sensor in my car today and while checking the theft det system I noticed the light kept blinking with everything closed and indicating the system would not arm. Since I havent had this problem since I got the hood I checked there first and sure enough theres no place on the hood to make contact with the hood switch! So now I have the hood switch unplugged so the system would arm but you guys should check cause even though the theft det sucks, if the hood isn't making contact it's not gonna arm. When you close the doors the light should go out until you arm the system at which point it stays solid for 30sec and then starts to blink. If it doesn't stop blinking then the BCM thinks that something is open.
Old May 6, 2002 | 08:37 PM
Cumalot's Avatar
Couldn't help you there. I still have the factory alarm. I will look into an upgrade later though.
Old May 6, 2002 | 08:39 PM
maximus75's Avatar
I'm talking bout the factory hood switch. I still have the factory alarm too. I just added a shock sensor to it.
Old May 6, 2002 | 09:30 PM
Cumalot's Avatar
Hm...I see. Don't know, my factory alarm still seem to work. So if this is the case, if I upgrade to an new alarm system with shock sensor, would I run into the same problem?
Old May 6, 2002 | 11:39 PM
GTRBlkMax97's Avatar
Re: People with Fiber Images C/F hood!
How did you fill in your grill like that? just curious, that is what i have been wanting to do for a while, just didn't know how it would look till i checked out your web site. car looks bada$$ by the way
Old May 7, 2002 | 02:30 AM
ptatohed's Avatar
Licensed to Spell
:o)
If it makes you feel any better, your car will arm itself eventually. It will take longer than the usual 30 seconds though. But the hood will not be protected.
Old May 7, 2002 | 06:26 AM
maximus75's Avatar
Re: :o)
Oh, good as long as it arms.
Cumalot, I added a shock sensor to the factory alarm. This way if someone breaks a window or jacks up the car it will set off the factory alarm.
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
