Question about SparkPlugs
Old May 7, 2002 | 08:35 AM
kushane's Avatar
My recently acquired 96 MAX has around 47k miles on it (purchased it at 44k). I know that Nissan recommends a Plug chage at 60k and my question to you guys is, how bad were the plugs when ou swapped them out at 60k or even a lower milege? Do you thinkk I'll get any benefit from changing them early or should I just hold on till closer to 60k? I know the easiest way would be to remove the pulgs and inspect them, but I don't have alot of free time on my hands and coupled with being a "lazy bum" makes a bad combo Thanks in advance!
Old May 7, 2002 | 08:42 AM
mcros's Avatar
A new plug will always perform better than a used one. Buy a set of NGK or Denso and throw them in.
Old May 7, 2002 | 08:48 AM
dwapenyi's Avatar
You will benefit. Stick with the stock NGKs. All the others have dis-advantages that come with their advantages, if any. BOSCH +4, some VQ motors destroy them, Denso, you have to change them earlier than the NGKs.
DW
Old May 7, 2002 | 09:01 AM
PhatBastard's Avatar
Which NGK?
Which NGK "model"? The NGK parts finder shows the 'laser platinum' as the oem replacement. Is this correct?
Old May 7, 2002 | 10:55 AM
95emeraldgxe's Avatar
Re: Which NGK?
yeap - NGK platinums are what you need
Old May 7, 2002 | 02:50 PM
kushane's Avatar
Thanks guys, Guys that decides what I'll be doing next Saturday afternoon.
Old May 7, 2002 | 03:00 PM
DJLAX152's Avatar
Bosch Platium +4 are good plugs they will not harm your engine and your engine won't destroy them!
Old May 7, 2002 | 03:15 PM
JAIMECBR900's Avatar
They may be good plugs for other cars, but for maxima's NGK and Denso is the only way to go.
Old May 7, 2002 | 05:15 PM
max808's Avatar
I'd wait until you reach 60K. I took mines out at 55K and they looked fine. To change the spark plug it should take you 30 minutes at most. The only hard ones to get at is #4 and #6. A word of warning, when you remove the ignition coils be gentle with them, they cost about $80 each, don't yank them out pull gently but firm. Also, number your coils as you reove them and put back in same cylinder, don't know if that makes a difference. Good luck.
Old May 7, 2002 | 06:07 PM
dwapenyi's Avatar
Good advice. And I'd like to add, do 1 cylinder at a time. Remove coil, replace plug, put coil back. Done. Next cylinder. Less chance of losing track that way.
DW
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
