Stupid Quesion-Air Pressure?
Old May 8, 2002 | 10:59 AM
MikeyMike's Avatar
Just curious what the recdomended air pressure for the summer is for 98 maxima with 215/55/16 are? I think this is the same size tire that came stock?
the max pressure on the tire says 44lbs- but the guy at Jiffy Lube said 30/33? can that be right?
Old May 8, 2002 | 11:03 AM
HondaKiller718's Avatar
Look at the sticker inside the top portion of the center armrest and junk holder. (between the drivers and passagers seat up front) The sticker will tell you reccommended cold tire pressures for all wheels. Remember once you are driving the air inside your tire will heat up and expand, so you don't want to be running too high a pressure. Also check your manual for the pressures. And do a search
Old May 8, 2002 | 11:50 AM
95emeraldgxe's Avatar
33/32
Old May 8, 2002 | 12:17 PM
BlackCat's Avatar
RIP '98 Maxima SE
32/29 if I remember correctly the last time I looked under the center glove box lid....
Old May 8, 2002 | 12:19 PM
njmaxseltd's Avatar
33/29 front/rear
Old May 8, 2002 | 08:19 PM
MaxVQ's Avatar
Re: Stupid Quesion-Air Pressure?
I don't use the factory pressures. I like to have a 6 PSI difference front to rear. Usually I run my fronts at 40 PSI and the rear at 34 PSI.
This makes the car steerable with the throttle in the corners.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
msellas
Sep 23, 2015 09:16 PM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 16, 2015 01:33 PM
