What is overdrive?
Old May 8, 2002 | 03:19 PM
SkiLlz's Avatar
What is overdrive?
I Realize that driving with OverDrive OFF increases my RPM dramaticallly. However, driving with it on in the freeway, decreases my RPM dramatically.
What is the difference between driving WITH OverDrive and WITHOUT overdrive?
Do I save more gas with O/D on or off? Does having O/D off make the car accelerate faster? How about in the long run? Does it matter?
Old May 8, 2002 | 03:23 PM
97BlackMax's Avatar
Re: What is overdrive?
OD OFF-4th gear locked, stays in 3rd
OD ON-4th gear opens
there's also something about the torque converter, but i forgot which way it goes, and i'm too lazy to think
with OD off, it just allows you to use 3rd gear to the full potential, accelerating faster
Old May 8, 2002 | 03:26 PM
MaxJag's Avatar
Does anyone turn off their OD. If so for what.
Old May 8, 2002 | 03:38 PM
AdMax98's Avatar
I would doubt that holding OD off would be beneficial unless you are doing high speed racing (where you'd need full revs in 3rd gear). If anyone thinks that it affects 0-60 acceleration, its all in your head.
So in otherwords, I dont think there is any reason to turn it off for daily driving.
Its basically like take the 5th gear out of a manual.
Old May 8, 2002 | 03:45 PM
97BlackMax's Avatar
there is no benefit in 0-60...the only real reason i can think of as to turning off OD is when you are in traffic that keeps shifting between speeds around 40-60...so that your transmission doesn't keep shifting between 3 and 4, you can turn OD off and it keeps it in 3rd, saving the gear changes...but it is really only useful to turn off in racing as AdMax said, or just trying to obtain your overall max speed
Old May 8, 2002 | 03:51 PM
Iqb316's Avatar
Keeping OD ON increases your MPG as well, or so the manual says
Old May 8, 2002 | 04:19 PM
RedMax95's Avatar
ya, i leave mine on unless i plan to be hitting the highway for some quick 70-90 pulls, its useless at lower speeds
Old May 8, 2002 | 04:51 PM
JsL's Avatar
JsL
Hey, when you guys drive about 30 or 40 on the streets, does your car feel like it's not strong enough to pull 4th gear when OD is on. I feel my engine shakes a little as I give it a little bit of gas in 4th while going 30 to 40.
MarcJD
Jan 19, 2005 11:32 PM
seth_js
Jul 16, 2001 05:03 PM
axion
Jan 6, 2001 11:42 AM
timmyl
Oct 11, 2000 04:58 PM
Cumalot
Oct 9, 2000 06:04 PM
