Conering Rewire
Old May 8, 2002 | 06:46 PM
ladeesman's Avatar
Conering Rewire
Does anyone have a write up for the conering light rewire on a 95? I've look and could just find 97 and up.
Old May 8, 2002 | 06:54 PM
aznsap's Avatar
ya, i actually did the rewire for the corners. there shud be a black wire, a black wire w/ a red line running along it, and a green wire.....i think. cut the wire w/ the red on it and splice it to the green one. shud run bright all the time now.
Old May 8, 2002 | 06:56 PM
97BlackMax's Avatar
does the shaving of the nub and flipping the bulb around not work in the 95/96?
Old May 8, 2002 | 06:59 PM
aznsap's Avatar
i wasn't rilly comfortable w/ that. neway, the rewire is hella ez. so if mah bulb blows or sumthin, i dun hab to cut the nub off again.
Old May 8, 2002 | 08:40 PM
lefty
I shaved the nub off in like less than 30 secs a side.
I try to avoid cutting wires in my car. But it is your choice.
Shaving is quite easy and quick...just get a good small file.
K.
Old May 8, 2002 | 09:41 PM
Mad Dhan's Avatar
nah, i did , it works fine, i have a 96 took me longer to get the blub out of the socket.
Old May 9, 2002 | 06:54 AM
ladeesman's Avatar
So you just shave the nub off the side of the metal prtofthe bulb and flip it around in the socket? Does that give the same effect as the rewire?
Old May 9, 2002 | 07:29 AM
njmaxseltd's Avatar
This post should be a sticky.
Lets call it how to destroy the english language.
What in the world are they teaching in the school systems these day?
Best of all, this guy has a drivers liscense? How did he even pass the WRITTEN test?
Amazing, simply amazing.
Old May 9, 2002 | 07:45 AM
QuEeNz MaX KiD's Avatar
You can also solder the 2 connections together on the bottom of the bulb.. takes a few seconds... shaving the nub as easy too... no need to rewire
Old May 9, 2002 | 08:35 AM
Mad Dhan's Avatar
yep, shave the one closest to the bulb and put it in backwrds. done. 1 min, no rewire junk.
Old May 9, 2002 | 12:41 PM
97BlackMax's Avatar
K.
or do what i did..if you have a brick house, rub the nub against the brick...much faster than a file
Sir Tilus
Mar 22, 2016 01:49 PM
Blackwind
Aug 5, 2015 06:35 PM
bad2rock
Jan 7, 2001 02:32 AM
96maxi
Jan 2, 2001 11:26 AM
