Front pads rubbing
Front pads rubbing
Decided to be adventurous and try to replace my front pads myself today. I'm not very mechanically inclined, but am trying to become so.
Took me forever, but finally got everything back together. Went for a test drive. Heard the dreaded rubbing, not really bad but definitely noticeable. Came home, realized that I had forgotten to put the little spring clips back in. Took wheels and calipers back off, replaced clips, and the pads are still rubbing even when I turn the hub by hand. I removed the caliper pins again and wiped off some grease. That didn't help either.
Trying to be a do-it-yourselfer like y'all, but getting discouraged.
I'd appreciate advice on where to turn next.
what kinda pads did u use? I replaced my OEM ones with Bendix (bad bad idea), and ever since then they squeak pretty badly, even when I'm not using the brakes, but just backing out slowly or something. Oh well, I'm just gonna wait till they wear down and then get me some real OEM nissan pads.
Re: Front pads rubbing
As for the rubbing, do you mean they drag a little bit on the rotor? Is it even all the way around or just in spots?
Re: Re: Front pads rubbing
Originally posted by iwannabmw
Where was the grease? Did you get any on the rotor or pad at all. That surface should be totally clean. If you did get grease there you will need a clean rag and some brake parts cleaner to remove it.
It's difficult to tell where they are dragging. Looking through the inspection window in the caliper, the pads appear to be resting on the rotor. Like I said, I'm new at this, so that could be normal. I did not use factory pads. I used non-metallic ones from NAPA.
The noise is difficult to describe, but it is clear to me that the pads on both sides are remaining in contact with the rotor. I get the noise both when driving and rotating the wheels by hand when the car is jacked. After a short drive, the rotors were very hot, and I know they can turn red hot if I would get on the freeway.
Thanks for the reply -- any ideas?
Re: Re: Re: Front pads rubbing
Originally posted by Pappa Grande
While we are on the topic - do you put anti squel goop under or above the retainer clips you put on the pads?
I put the grease only on the caliper pin. I was careful to not get anything on the rotor itself. I did get a little of the blue goo on there, but it came right off. That wouldn't cause this problem though, would it?
Just curious, did you use a c-clamp to push in the caliper piston? If so, did the piston slide easily or ??? Since you greased the caliper pins it sounds like the piston itself may be binding.
To "test" your calipers... you could try removing the pads and putting the caliper back in place and bolt it in. The caliper should slide back and forth on the pins with no binding. If it does bind... find the bent or damaged pin. Did you reverse the pins when reassembling? Just a thought... dunno if that could cause the problem. If it doesn't bind the problem is elsewhere.
Did you put a tiny amount of grease where the metal plate of the pad slides on the locating springs in the bracket? How hard was it to rotate the caliper back down over the new pads? If it was very hard (and the piston was bottomed) it is possible the pads are too thick and the caliper cannot retract enough. In which case, sand off some of the pad material using medium to coarse sand paper on a flat surface.
With COLD brakes bring the car up to about 10 MPH, put it in neutral and let it coast to a stop. Does it do so very slowly? Or kind of quickly?
If kind of quickly, and you have tried all suggestions, then you are probably better off taking it in to a professional.
BuddyWh
Re: Re: Re: Re: Front pads rubbing
BuddyWh
BuddyWh
That's just a guess...
BuddyWh
It is normal for pads... especially new ones... to drag a little, but just a little. As the wheel rotates the caliper should retract and relieve that. Did you put on new rotors or have your rotors resurfaced? That can make a rubbing noise as the pads and rotors are bedded.
BuddyWh
BuddyWh
Reassembly was confusing, but I think everything got back together fine. The caliper went back on easily. The confusing part was the orientation of the brackets (stamped T facing up, I think) and the pins (brass one with black rbis up, again, I think). I couldn't find good documentation on that. The caliper was not difficult to put on. I didn't have a large enough C clamp to push the piston back in, so I used a quick-clamp (you know, the hand-operated woodworking ones), with an old brake pad on top of the piston to distribute the force. It went back in without trouble, and yes, I had unscrewed the resevoir cap.
After reading your first paragraph, I'm thinking I might just be paranoid. I did have the rotors turned. I thought the noise was possibly normal, but I'd never heard anyone mention it before. It's not loud, and it does not change the stopping characteristics of the vehcile, i.e. it doesn't stop more quickly than normal. I wouldn't really be able to hear the noise unless I was listening for it. It's one of those you hear when the windows are down and you're driving by a curb or building that will reflect the noise. I haven't driven far enough for it to stop if it is normal.
Maybe I'll just leave them alone and see how it goes. I guess I do have an e-brake.
Re: Re: Re: Re: Re: Front pads rubbing
Great reply, thx for the suggestions.
Reassembly was confusing, but I think everything got back together fine. ...
I did the same once... but with rear drum brakes on an old Civic... I thought I'd NEVER get those brakes back together right! So many springs and clips... does this one go on top? no... take it back apart... ok how about this one?? ARRGH The diagrams from the Motor's manual I got at the library was WORTHLESS! And I had done drum brakes before!
Properly bedding new pads/rotors can make a major difference too: Bring the car up to 50-60 MPH and brake to a stop with moderate pressure, then drive 5 min's to cool the brakes. Repeat three times. Then do the stop twice in succession before driving around, repeat three times again. If you want, do it three times in succession before driving around (you might experience fade now if these are street pads). There are many bedding processes, this is the one I use.
After this, you will probably find the noise is gone... and initial braking should be far more secure feeling if these are street pads.
BuddyWh
bendix
bbsitum
Sep 11, 2015 04:55 PM
Hdnseek
Sep 9, 2015 05:55 AM
