Clutch noise
Old May 11, 2002 | 11:44 PM
chrisco
Clutch noise
I drive a 97 manual SE. Does anyone know what causes a squeeking noise when pushing the clutch in and then as well when letting the clutch out? No noise when it's wet out though. Thanks, Chrisco
Old May 12, 2002 | 11:41 AM
xHypex's Avatar
Re: Re: Clutch noise
Originally posted by Supai91
Something called release bearing .
you should find that when you get a new clutch like act , it's comes complete with the kit.
you can get that sapretly , but it's better to replace a new clutch with the time you change that
The noise is the throwout bearing. It is usually replaced when you get a new clutch and sometimes even comes with the clutch kits (i.e. ACT). Just live with the noise till you get a new clutch and try not to hold down the clutch excessively from now on (like when you sit at a light). The longer you hold down the clutch the more the bearing wears. Just FYI so you don't get a squeeky bearing next time
-hype
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
