Hood struts....
I talked with Jeff K. about this some time back.
I need new Hood Struts so far I've tried Schucks (local autoparts store) and Pep Boy's. Niether have the size the Max needs. I'd rather say away from Nissan's as the one's I have only lasted (2) years. Any leads on these?
Wizeguy
Wizeguy
Originally posted by Black95Se
How much were the stock ones? Mine only want to hold my hood up if I've been running the engine for awhile and they get warm. Thanks
The stock were I think $79 each and then you have to buy the ball bearings which were $20,Complete Rip Off,But at least my hood stays up now and that is Priceless.
Originally posted by Micah95GLE
Jamex makes chrome hood shocks. Does anybody know if they have a fitment for Maximas? Mine don't work too well, either- especially when it's hot.
By some new ones
I tried to find hood shocks everywhere, but no one had one for the maximas. Eventually after using the club for about 1 year to hold up that heavy hood I order new hoods shocks.The dealer around myway(bronx) was asking 90 bucks. I eventually got 2 new ones from courtesy nissan for about 66 bucks each.
by the way the part numbers are:
left hood shock(65470-40u00)
right hood shock(65471-40u00)
hope this helps
hope this helps
Wizeguy
Wizeguy
You likely only have one that is bad. They say to replace in sets, but I don't know why if one is just fine. Aren't you using hood with one bad strut now? I can see if hood would rack or bend with one bad strut, but they are too weak to cause that. Old hood springs were different: If one was bad, the hood would get tweaked bad when closing it.
Pull each one off and depress. You will know which one is bad. If both feel the same, then replace both. Or if you have the cash, buy two new ones anyway.
Originally posted by TooMAX
Go to partsamerica.com and search for strong arm - they used to have them for $16 each but now are twice that... But WAY cheaper than buying from the $$tealer
They are worth the money since they have lifetime warranty
MIGHTY-LIFT HATCH/HOOD/TRUNK LIFT SUPPORT for a 1997 NISSAN/DATSUN MAXIMA
Unit Price: $19.99
Core Value*: $0.00
Part No.: E95784
Weight: 0.6 lbs.
Warranty:
Availability: Online: Ships within 2 business days
Store: Normally Stocked
Note:
NONE
Unit Price: $19.99
Core Value*: $0.00
Part No.: E95784
Weight: 0.6 lbs.
Warranty:
Note:
NONE
I wouldn't spend the money to replace the struts. Buy yourself a small, cheap locking pliers and lock it right at the strut when the hood is up. I think it's the most efficient way. 2x4s or putting a stick is ghetto looking and dangerous. The locking pliers work great.
All I'm saying is that's my preference. For $40 bucks I can do a lot more than get hood struts. Just like others say they put 2x4s, I just wouldn't go that route. Besides, I don't do car shows so I don't care. I still think it's better than carrying a block of wood around!
AaronL
08-08-2020 10:31 AM
Unclejunebug
04-02-2016 05:42 AM
