MPG worse after changing fuel filter
Old May 13, 2002 | 08:18 PM
NyC97Max's Avatar
hey i dunno why but my gas mileage got WORSE afte changing my fuel filter, i thought it would help get me some better mileage, but only made it worse..didnt expect that. I dont think there are any leaks, how can i securely and 100% check for leaks? my idle is also alot lower after the replacement
Old May 13, 2002 | 11:49 PM
spiff56747's Avatar
well i'm no expert, but maybe since your fuel filter is not clogged anymore, its allowing more fuel to go into the engine, so thats why your economy is lower.. again i'm just guessing
Old May 16, 2002 | 09:38 PM
krbga's Avatar
I'm not calling you dumb...but...
...is it mounted in the correct direction ie. up/down
also double check to see if ther is a leak, crack or puncture in that small line that might have happened during you change out.
Old May 16, 2002 | 10:35 PM
NyC97Max's Avatar
yes it is mounted the right way, good point though..ill double check the hoses 2moro morning, thanks
Old May 16, 2002 | 10:56 PM
NYCe MaXiMa's Avatar
hmm
this might sound stupid or might really be a dumb idea... but... maybe you should try resetting your ECU.... disconnect the battery and let it sit for a little bit... then reconnect it..
What i am thinking is, it might take a little bit for the ECU to adjust to it. If your old one was clogged, it was adjusted to a certain air/fuel ratio.. sending fuel at a higher pressure so the right amount would get to the injectors even with it clogged... now that it's free, it is still used to the pressure of the old fuel pressure and even more fuel is going through.. could be, i'd give it a shot, besides that, nothing else makes sense if there are no leaks or anything. unless the fuel filter u bought is defective
Old May 17, 2002 | 06:24 AM
dwapenyi's Avatar
Re: MPG worse after changing fuel filter
Check and possible clean your air filter. CAI filters get dirty fast b/c of their down lo location right next to the front wheel.
DW
Old May 17, 2002 | 06:53 AM
mtrai760's Avatar
'Trynna' is not a word
You might have a slight leak that is really hard to notice. When I got my car back from having the tranny replaced, I noticed my gas milage was horrible. I checked and checked but could never find any leaks. So finally one day I take my car full throttle down the street, then I stopped quickly and pull over, pop the hood, and Ta-da, find the fuel leak. Seems Nissan didn't tighten the lower clamp back up on my fuel filter. Wouldn't leak just driving around town, but when I got up to speed, it would start to leak pretty bad. Gas evaporates pretty quickly, so you have to be quick to check it. Check all the other hoses in the area you were working in also, maybe you pulled something loose and didn't notice. Good luck.
The Wizard
24
Oct 1, 2015 08:47 PM
aminus21
Sep 12, 2015 04:53 PM
thenewguyy
Sep 12, 2015 11:12 AM
sdotcarter
Sep 2, 2015 09:53 PM
