Have a Noisy Suspension problem (not from the Springs)
I recently change the shocks/struts and still have a noisy front end. I thought by changing the shock this will solve the problem but that was not the case. My car has 87k and takes a lot of beating from driving in the city. I redid the springs and followed the recommendations posted by “LIME” (thank you all) but the noise is still there. It has a rippling sound effect when driving over local roads and not very noticeable on the highways. I took a ride in other Maxima’s and they did not have this problem. I am considering changing all the bushings on the front end and the front wheel bearings. Any suggestions? Does anyone else have this problem?
Re: Have a Noisy Suspension problem (not from the Springs)
Re: Re: Have a Noisy Suspension problem (not from the Springs)
Originally posted by SLC I30t
I think that replacing the bushings in the strut tower assembly(or whatever its called) might help. I did the spiral wrap on my springs and I still get noise. I'm going to try doing it another way, but I am also going to do the upper boot/bearing replacement to be sure.
When I change the Shocks, I replaced the tower mounts and tower bearings. (Save your time) I also did the spiral wrap on the springs. I am sure that is not the problem. I am suspecting, it’s either the bushings on the Stabilizer Bar/ Control Arm but not sure. It could be the wheel bearings. Has anyone heard of wheel bearings causing rippling noises?
yeah they will make noise but you can check that by lifting your car with the wheel in place and push and pull on the rim and wheel. the whole car should rock a little. if the wheel wobbles the bearing is shot... also you can feel the rim after a drive, if it is OMG hot... thats an indication of the bearing going...
I just replaced my front (upper) strut mounts. These are the rubber parts that mount the top of the strut to the strut tower. The rubber part of my passenger-side mount had COMPLETELY separated from the metal mount housing, causing a nasty clunking noise over wavy pavement. It also caused some odd vagueness in steering response and handling. My mounts had 104K miles on them.
You may be experiencing the same failure. However, I kinda think you would have noticed the problem when you did your struts/springs.
You may also want to check and make sure all the bolts from your front struts are secure. I've gotten a similar clunking sound from the front struts when the upper strut-to-mount nut was loose. Make sure that one and all the others are tight.
Re: Re: Re: Have a Noisy Suspension problem (not from the Springs)
thats the type of road that gives me a hollow vibrating noise in my car.
What kind did you use, I got the 1/2 inch spiral wrap from Radio Shack. I'm thinking I need to get something more heavy duty, or maybe its not my springs.. Oh well, kinda dissapointed after a day of taking apart my front suspension..
I used the same, but I think that the tone of clunkiness is going to change when you change suspensions(struts) Perfrormance struts just may make a different noise. Mine is slowly subsiding, it also may just be a break in perios?
Mar 12, 2020 12:06 AM
Violator
Sep 9, 2015 10:14 AM
