Exhaust (Greddy CB) Change... Did You Have Trouble With The Rusted "Specialty Pipe"??
Old May 14, 2002 | 06:22 PM
NiceGuyEddie's Avatar
Exhaust Change... Did You Have Trouble With The Rusted Cat. Converter Bolts????
I cut the ends off the bolts and it still won't budge... Anybody else have that problem??? It also looks like the pipes are rusted together also... I have a 97 and I can't believe the rust!!!
Also, I broke off the sensor... How much is a replacement???
Old May 14, 2002 | 08:32 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Exhaust Change... Did You Have Trouble With The Rusted Cat. Converter Bolts????
The O2 sensor is 60ish online. Use an open end wrench next time for the O2 sensor. I used breaker bars and couldnt take those two bolts off so I ended up with air tools
Old May 14, 2002 | 08:37 PM
Re: Re: Exhaust Change... Did You Have Trouble With The Rusted Cat. Converter Bolts????
The sensor was no good anyway. The rust was horrible.
Did you cut the bolts?
Old May 14, 2002 | 08:40 PM
turbomax97's Avatar
Re: Re: Re: Exhaust Change... Did You Have Trouble With The Rusted Cat. Converter Bolts????
no sir. I soaked the bolts at intervals, then took it to the exhaust shop and had him put an impact wrench to it. I think it was pretorqued to 150ish.... They came write off.
Old May 14, 2002 | 09:06 PM
Re: Re: Re: Re: Exhaust Change... Did You Have Trouble With The Rusted Cat. Converter Bolts????
Mine were really rusted..
RealityCheck
Oct 2, 2015 06:34 PM
Justin Kroll
Oct 1, 2015 07:03 PM
uttadms31
Sep 30, 2015 05:24 AM
Socalstillen
Sep 26, 2015 12:01 PM
