16" rims and a lip?
16" rims and a lip?
I have 225/50-16 rims and I would like to know how low would it be up front with a stillen lip? Can some one meassure the distance between the lip and the ground or post pics of the front end. Thank you.
Re: 16" rims and a lip?
Re: Re: 16" rims and a lip?
Originally posted by MaxSpeedSE
Do you have a drop? If not you should be fine, if you have a drop, i have a 2 inch drop and with out a lip im about 8-10 inchs off the ground... even with out one i still have to drive carful, so i say , the same to u..
i have the progress 1.7 drop and a lip. scrape like a **** if you dont go up entrances to parking lots and such carefully. i realize i have to go in sideways. but whatever, it happens man. the lip looks dam good though.
car on the right
225/50/16
lowered 1.6" with lip
about 5.5" off the ground and I sometimes scrape stuff. Nothing bad really just rubbs against really steep curbs and driveways. Nothing bad but it takes getting used to driving up everyting at like a 45 deg. angle
225/50/16
Originally posted by Max4U
I think you would be scraping the lip, get some bigger rims 17" lifts you up an extra inch. and you will be OK.
Re: Re: Re: 16" rims and a lip?
Originally posted by Nismo
17s wont get you car higher. It will be the same diameter as a 16" rim, only it will have more rim and less rubber.
Re: Re: Re: Re: 16" rims and a lip?
Acutly when i got my 17s, i got the same tires size the recomended on MaximaDriver.com and everything, and it brought up my car a Inch
They wouldnt do anyhting cause 45-17 rims is the same as 50-16 If I were to get 50-17 then its different story.
Do you want to measure rims to show you that my wheels are bigger than your 16" thats saying if you put a 65/15 wheel next to a 45/17 wheel it would be the same size. No I don't think so.
~Manoj~
Re: Measured!
My rim+tire size is 24" and quater. Whats yours Klive?
Re: Re: Measured!
Sorry but I don't have a tape measure. But I have a question for you, when I had my 15" GLE rims and changed it to my 17" Tantrum why did my car sit up an extra 1" or so like a 4x4 thats why most of us get a drop because after getting bigger rims our car jacks up more. Explain that to me ?
The 17" wheels/tirs can very well life your car up .5" or so. But it's not the wheels, it's the tires. There's more slack in the sidewall of a 15" tire than in a 17" tire. So the 17" tire sits straight and there's your extra .5"
-Cyrus
-Cyrus
Re: Re: Re: Measured!
Theoretically it should not change but hey, get the tape measure and I will be happy. Im not arguing just trying to see how bad it would be with 16s. Thanks for all the imput.
Re: Re: Re: Re: Measured!
I'm not flaming Val , but when I had my 15" GLE rims in the winter with my drop my car was real low, but when I changed it to 17" it sit up a little and now that I have my lip I don't know whats gonna happen this winter when I put the 15" back on.
is there any way you can get a tape measureer?
seriously though, by logic it should not sit higher with rims that are up to 18" ofcourse if they are the right profile.
15" stock rims have a higher sidewall/profile.. When u get a bigger rim, the tire sidewall/profile gets smaller.. the bigger the rim the smaller the tire.. so they even out and overall it is still the same... or at least should be
example:
stock 15s have a 65 profile
stock 16s have a 55 profile
aftermarket 17s are paired with 45 profile
18s are 40 though.... i guess 18 might be a little bigger.. although i heard that everything up to 19" is okay....
example:
