Hybrid Intake Question
Old May 15, 2002 | 10:08 PM
StaindMaxima's Avatar
Today I installed my Stillen pop charger into my 99. I used the upper portion of my PRCAI, in place of the velocity stack. The filter sits in the same exact place as it did when I had the pop charger installed originally, so the only difference is the PR pipe vs. the velocity stack. I was even able to use the bracket that comes with the Stillen intake that bolts onto the MAF.
Q1 Which is better, the velocity stack or the PR tube?
Q2 Is this really a hybrid intake, or did I miss something?
Ryan
Old May 15, 2002 | 10:42 PM
iregula's Avatar
can u tell me if you saw a difference with the upper tube...im interested in doing that in getting back the LOW END i lost
Old May 16, 2002 | 11:47 AM
Anachronism's Avatar
Re: Hybrid Intake Question
Ryan
Do you mean you replaced the resonator with the PR upper? I think the velocity stack is built into the filter, did you use the MAF adapter that came with the CAI or just bolt the filter onto the MAF?
Old May 16, 2002 | 01:09 PM
95emeraldgxe's Avatar
Re: Re: Hybrid Intake Question
the velocity stack is the way that the filter connects to the maf. If you want mid to high end power you use the PR tube, if you want high end power you use the velocity stack.
btw - yes, that is a real hybrid intake, the upper pr tube with the filter
Old May 16, 2002 | 10:08 PM
To be honest, no I did not notice much of a difference, if any at all by using the upper tube. It just looks better I guess, seems to be all it's doing for me. Sounds a little better too maybe.
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
