What effect do disconnected O2 sensors have?
Well, I disconnected my right O2 sensor and the hesitation is gone and my MPG have already dramatically increased.
I'm not getting the Check Engine Light, and I think it's because the circuit has a short somewhere. I changed my Seat Belt idiot light bulb into the CEL socket and it no longer worked. Neither did the CEL bulb I moved into the Seat Belt idiot light socket. So I have no idea if I'm throwing codes.
Will a disabled O2 sensor DAMAGE my car? Will the car rely on the air/fuel mix it's programmed with -- the one it uses at wide open throttle?
Get new bulbs for the CEL and Seat Belt Idiot light. A short will not blow those bulbs, there 12 volt bulbs. Put 12 volts across them, they light up! Pretty simple theory. Your car only has 12 volts in it. A short will cause them not to light but will blow a fuse or damage the ECU.
Originally posted by lgsmaximaman
becuase u have taken the o2 sensor out the ecu is in a constant loop so the cel light will not come on.......
So I guess running with an O2 sensor disconnected is OK as long as my MPG stay up?
Now my concern is with the circuit the CEL is on...
Originally posted by maxxed
I can't see how you could disconnect a sensor without setting the check engine light.
Did you check the ECU for codes?
my03maxima
Jul 28, 2024 07:40 AM
maxima297
Sep 30, 2015 03:32 PM
