One touch sunroof install
Old May 17, 2002 | 12:03 PM
maximus75's Avatar
This will also be on VQpower
Installing one touch feature on sunroof.
Installing the one touch feature on 95-99 Maximas using the WC1000 requires you to change the polarity of the sunroof motor. This is because the motor runs of of a negaitve trigger and the WC1000 uses a positve trigger. This will present some problems. The sunroof motor will get confused in a certain position due to the polarity change. For example: If your sunroof is open, after you "one touch" close it you will have to "tilt" open and then closed before you can one touch open it again. This sounds like a pain but you get used to it. If this sounds like something you don't want to deal with then don't do this install. Other than that I haven't had any other side effects. Now to start the install.
1) Remove the little "wings" on the side of the WC1000(pic 1) and remove the dome light/sunroof switch assy. It is clipped in so use a panel puller or small screwdriver and gently pry it down on the dome light side.
2) You will see a brown connector betwen the switches and the cars harness(pic2). We're going to concentrate on the harness side. Cut a slit through the black conduit and peel it back to expose the five wires. They should be black, blue, white, green, and brown. Green and brown are the slide triggers. You will need to cut the blue, white, green, and brown wires.(leave enough room one both sides to work with)
3) Now connect the blue wire from the cars harness to the white wire at the brown connector and do the same for the white wire (white wire at harness to blue at connector) Your basically just switching the two wires.
4) Now you need to reverse the polarity of the sunroof motor. If you pull down on the headliner where it meets the sunroof(pic3) you will see a blue wire and a red wire coming out of the motor. The blue wire is a ground and connects to the cars frame. The red is power and plugs into a connector by the windsheild. Cut these wires and swap them so the blue wire now receives power and the red ground.
5) Here's where the WC1000 comes in. The WC1000 needs power and ground which can be retreived from the dome light circuit. Peel back the conduit on the harness going to the dome light to expose the red and black wires. Tap into these for power/ground for the WC1000. Now connect the green wire from the car harness to the green wire on the WC1000. Next connect the brown wire from the car harness to the blue wire on the WC1000.
6) Now at the connector on the car connect the brown wire from the car connector to the brown wire on the WC1000. And then connect the green wire from the car connector to the white wire on the WC1000. You can squeeze the WC1000 under the headliner on the passenger side. There is room between the metal braket and roof. You may want to insulate with foam. Thats it.
Depending on where the roof was when you started you may have to play with the switches to get it to orient itself, but the roof should now one touch slide open and closed.
pic 1
pic 2
pic 3
Old May 17, 2002 | 07:15 PM
maximus75's Avatar
May want to add this to the FAQ
Old May 17, 2002 | 10:39 PM
bigd480's Avatar
Re: One touch sunroof install
Thanks I've been waiting for a write-up like this for a long time.
Is there a best position to have the sunroof in when you do this?
Also, are you saying that you have to tilt the roof open/shut every single time between auto-opens or only occasionally?
Old May 17, 2002 | 11:36 PM
maximus75's Avatar
Re: Re: One touch sunroof install
Every time and it doen't matter where the roof is when you install.
Old May 18, 2002 | 12:29 AM
Cumalot's Avatar
WC1000? Do I need to buy this or is the unit already there?
Nice write-up.
Old May 18, 2002 | 09:59 AM
maximus75's Avatar
Nice write-up.
You need to buy it from autoloc. I think it's like $40 or so.
Old May 18, 2002 | 12:34 PM
bigd480's Avatar
Re: Re: Re: One touch sunroof install
If you press tilt up/down after the roof has auto-opened would that be satisfactory to "reset" it or does it have to physically tilt up/down?
I don't know a whole lot about electronics but maybe if you can explain what's causing this someone can help figure out a workaround?
rnb754
Sep 14, 2015 11:39 PM
Vequity
Sep 10, 2015 05:26 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
mikebla
Sep 3, 2015 05:37 PM
